Ucompressed data?
#1 Krstic Zoran
Krstic Zoran
  • 6 posts
  • Digital Image Technician
  • Belgrade
Posted 04 April 2010 - 09:52 AM
How many bites was made if all of data from CCD is digitalized first...of course before MPEG4 compression in case of F23 or F35!?
3 x 74.25 MHz x 14 bits = 3118.5 Mbps /4:4:4
or
3 x (1920 x 1080) x 14 bits = 87.0912 Mb x 25 fps => 2177 Mbps
I think that first equation is right...but in book "High definition cinematography" Paul Wheeler (second edition) was explained second equation (for HDW-F900,but same story... :) ).
My second question...
RED ONE has CMOS sensor at 4096 x 2304/12 bits.
Uncompressed RAW => 4096 x 2304 x 12 bits = 113.24 Mb x 25 fps = 2831.15 Mbps
How much bytes would be made for RGB 4K (uncomressed)? There : http://www.redoneafrica.com/redone.htm, was written that RGB 4K uncompressed made 1313 MB/s, how?
Sorry for too much maths ;)
#2 John Sprung
John Sprung
  • 4635 posts
Posted 05 April 2010 - 02:26 AM
The 74.25 MHz thing is from old time analog HDTV. The right answer on uncompressed bit rate is to multiply out colors, pixels, bits, and frame rates:
For 4:4:4 RGB you have three color channels, 1920 x 1080 pixels, 14 bit depth, and 25 frames per second:
3 x (1920 x 1080) x 14 bits x 25 fps = 87.0912 Mb x 25 fps = 2177 Mbps
For the Red, with its Bayer mask, you have one color per location, 4096 x 2304 photosites, and again 25 frames per second:
1 x (4096 x 2304) x 12 bits x 25 fps = 113.24 Mb x 25 fps = 2831 Mbps
RGB 4K, given the same height, bit depth, and frame rate would be 3 x 2831 Mbps = 8493 Mbps
1313 sounds like it's compressed.
#3 Harrison Hui
Harrison Hui
  • 1 posts
Posted 22 April 2010 - 04:17 AM
Hello, er 1313MB/s is correct as 8 bits = 1 byte. So 8493Mb/s = 1061.625MB/s.
Rather massive file sizes if you think about it. Per minute of footage is around 60GB.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 22 April 2010 - 01:01 PM
Ah, yes, thanks -- you're right. It's the old bits vs. Bytes thing.
At 60 GBytes per minute, you can easily get half an hour on a two TeraByte drive. So, it's within the range of practicality now. S.Two and Codex are doing it -- uncompressed raw -- with the new Arri Alexa.
