7285 super 8 as black and white
#1 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 11 April 2010 - 09:28 AM
Can this new super 8 stock be processed as black and white reversal? Or negative? What would the results look like?
#2 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 11 April 2010 - 10:00 AM
Definitely not Chris.
This film is E-6 colour reversal and cannot be processed through ANY B&W chemicals.
If it's put through a B&W process you'll get nothing on the film as it requires a bleach step ( at high temperature ).
The only other thing you could do with '7285' is to 'cross process it' ( as a special effect negative ) through process C-41 ( colour negative ) but that's if you can find a lab that runs C-41 16mm for cine - you won't find an 8mm C-41 processor though.
I don't know if anybody here on the forum has any experience of processing this emulsion through ECN-2 - maybe they can enlighten us ?
Hope that helps,
John S :rolleyes:
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 12 April 2010 - 03:33 AM
I agree a John idea , but, I wish add a some notes.
Yes, 7285 100D film have E-6 technology processing, but, if you wish have peculiar artimages, you can replace a color developer on other type of one-colour dye.
At final you will have one color slide image.
The dye can be chemical solution for B&W photo paper, special formulas for B&W print films, other dye.
Any case, this can be interested experiments.
#4 John Salim
John Salim
  • 190 posts
  • Essex, UK
Posted 12 April 2010 - 08:18 AM
No Olex, E-6 ( colour dev ) doesn't work like that.
To produce colour dyes, chemicals react together with the film's colour couplers.
It's not a case of adding colours in the process which is what I think you're saying.
John S :rolleyes:
#5 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
Posted 12 April 2010 - 09:23 AM
John S :rolleyes:
Hi John
May be you right, we use of adding colours at processing of B&W reversal film and had very good result.
About E-6 we do not make experiments, I show of my supposition only.
Any case, the guys can checl this ideas by test, need a russian spiral tank UPB-1, UPB-1A, chemisrty, and short ends of S8 films.
