avisynth
11 replies to this topic
#1 julien doumenjou
julien doumenjou
  • 52 posts
Posted 14 April 2010 - 11:30 PM
Just curious, I heard about avisynth. What is it doing that after effects doesn't ? Is it really interesting?
#2 Freddy Van de Putte
Freddy Van de Putte
  • 44 posts
  • Flanders, Europe, Belgium
Posted 20 April 2010 - 01:00 AM
Avisynth is basically a frame server. It opens a video file, applies all kinds of filters and modifications and serves this virtual clip frame by frame to another application.
It works with plain text files. Avisynth has his own scripting langue. It's open source.. free of charge. It works very fine together with VirtualDub.
Avisynth has his own, build in plugins. But lots of other plugins are available as *.dll files. They are all written by amateurs. Some of those amateurs are very talented. With the MVTools package for example it is possible to do very sophisticated grain removing and frame interpolation.
See my example files on Vimeo:
View on Vimeo
Fred.
Edited by Freddy Van de Putte, 20 April 2010 - 01:02 AM.
#3 Bruce Taylor
Bruce Taylor
  • 482 posts
Posted 20 April 2010 - 06:09 PM
Freddy, I have seen your work on vimeo. It is hard to believe what you do is possible, but there it is.
Is there anyone out there doing it commercially? I have a pile of 8mm and S8 reels I would love to see transfered with the quality you demonstrate.
Bruce Taylor
#4 Freddy Van de Putte
Freddy Van de Putte
  • 44 posts
Posted 21 April 2010 - 01:02 AM
Hi Bruce,
As far as I know, no one is transfering 8mm films like I do it (with machine vision cameras)commercially. But the HD Sniper from Moviestuff comes close. You can ask them for a frame accurate transfer: one film frame= one AVI frame (progressive). Uncompressed to harddisk if possible. Those uncompressed frame accurate AVI files are ideal to keep as master files and for later Avisynth use. The Huffyuv lossless codec can reduce the size of these files without any loss. The play speed of a frame accurate AVI file is not important, it's just a number in the header of the file, telling the computer how many frames/sec to show. Easy enough to change this in post.
Fred.
#5 Freddy Van de Putte
Freddy Van de Putte
  • 44 posts
Posted 22 April 2010 - 06:28 AM
I have just uploaded a new example clip on Vimeo:
View on Vimeo
Imho it shows very well the power of Avisynth.
Fred.
#6 Brad Masson
Brad Masson
  • 4 posts
Posted 10 August 2010 - 11:18 AM
Hello fred, I am a big fan of your clips on Vimeo, and I would like to start using the avisynth software for editing. I shoot reg-8 and am planning to do a Rank transfer, uncompressed to a hard drive. This will be the first time I have done this. I realize it will be AVI, but I am not sure what codec to apply; I'm assuming MPEG4? Maybe you can tell I'm new at the computer end of things, but I do want to learn. Any advice you can offer will be appreciated. Brad M.
#7 Phil Rhodes
  • 12168 posts
Posted 10 August 2010 - 11:51 AM
Did the people who are doing the job tell you this? If not, best to double check, because there are many approaches to doing this and only one of them is AVI.
The only way you will need to decide what codec to use is if they ask you. Otherwise, you'll get whatever they give you, and you will need to ensure that your computer is set up with an appropriate decoder. This isn't usually a problem, since most transfer places will use one of the Blackmagic uncompressed codecs which are cheap or free. Although you could, you don't really want to use MPEG-4; it's a distribution codec and while it has great performance for Youtube, it isn't ideal for mastering work. If they're saying it's uncompressed, it won't be MPEG-4, anyway.
AVIsynth is a great piece of software, mainly for jobs such as batch conversion, recompression, rescaling and applying burnins.
Freddy, as always, you've got some really good work going on there. I am extremely impressed. Care to talk some more about how you're doing the original transfers?
#8 Freddy Van de Putte
Freddy Van de Putte
  • 44 posts
Posted 11 August 2010 - 01:00 AM
Thank you Phil!
Sure:
I am using a relative cheap machine vision camera, 1024 x 768 pixels. In trigger modus, a machine vision camera takes one picture when it gets a pulse on the trigger input. Then it waits for the next trigger pulse and so on. The trigger pulse is generated by the projector, with an optical IR switch. So every time a new frame arrives, the camera takes a picture of it. Then the software is saving this picture as an AVI frame to a 'growing' AVI file. I always use uncompressed RGB for my masters. Play speed of the projector does not matter. The result is always one film frame = one digital frame. I can even stop the projector while in capturing modus. Then the camera and software will just wait for a new frame to capture. This stop will be not visible in the end result. Variable speed has also no effect whatsoever on the end result. The maximum capture speed depends on the computer system. With a fast computer and Raid-O harddisks, it is possible to capture at 30fps in full resolution. It is also possible to save an image sequence (TIF or BMP). The software is auto numbering the files.
The machine cam is sending the frames over the fire wire to the computer in an uncompressed, not debayered format: Y800. The capture software is doing the debayering on the fly. So the preview is in full color, and the saved result too.
For more information please visit my website
Some pictures are outdated, I must urgent do a website update.
Frank Vine has developed special capture software, based on the ActiveDcam engine. This software has an exellent HQ debayering option, live RGB histogram while capturing etc...
http://www.cine2digits.co.uk/
Frank is also developing a special RGB backlight source.
I have one here and I will test it as soon as possible.
I'm using a Computar macro zoom lens, so my camera is 'looking' straight to the film frame. For the backlight I'm using 5W White Luxeon Star Leds. Later I will use Franks RGB light source of cource. To diffuse the backlight I'm using a piece of 'scanhancer' plate.
http://www.scanhancer.com/
Many greetings from Ghent, Flanders, Belgium
Fred.
#9 Freddy Van de Putte
Freddy Van de Putte
  • 44 posts
Posted 11 August 2010 - 02:51 AM
Thank you too, Brad!
Please ask them for a one film frame = one digital frame transfer. Progressive, no interlacing if possible.
Like Phil already has said: Mpeg4 is a distribution format. Do not use it for a master file. If you are on a Windows machine I would suggest to ask them if they can deliver the files in uncompressed RGB24 AVI format. You will have to give them a portable HD then because those files are huge.
Fred.
#10 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 11 August 2010 - 07:47 AM
Is there anything with the features of Avisynth that works with Mac OSX?
Cheers,
Jean-Louis
#11 Brad Masson
Brad Masson
  • 4 posts
Posted 12 August 2010 - 11:21 AM
Fred.
Thank you gentlemen, you have been a big help. Brad M.
#12 Friedemann Wachsmuth
  • 122 posts
  • Hamburg, Germany
Posted 25 August 2010 - 06:54 PM
avisynth works great with Parallels.
