Super 16mm modified Krasnogorsk-3 footage
#1 Raz Birger
Raz Birger
  • 46 posts
  • Israel
Posted 15 April 2010 - 02:35 PM
Hello again,
as I promised in my previous thread (http://www.cinematog...showtopic=45513), now I post the video transfer of my test roll which was a test of my modified super 16mm Krasnogorsk-3.
Here is the edited version of the first indoor part where I tried to sync sound to the footage (the camera as you know is not crystal sync):
View on Vimeo
And here is the whole roll unedited with the outdoor footage in it's the second part:
View on Vimeo
There was a light leak which appeared outdoor, next time I will use some tape to cover.
Best Regards,
Raz Birger.
#2 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 15 April 2010 - 04:11 PM
...There was a light leak which appeared outdoor, next time I will use some tape to cover.
Looking at the leak, I'd try a flap of camera tape over the footage counter window.
Despite having renewed all the sealing foam around that area when I first got my K3, I found there was a light leak about 19 frames either side of where the film had stopped in the gate at the start/end of each shot. This gave a similar effect to what you're seeing and obviously wastes about the first and last second of each shot. With a little flap of tape over the window (I folded the end over so I could still easily lift it up to breifly see how much film remained) I never experienced the problem again.
#3 simon lomax
simon lomax
  • 2 posts
Posted 23 April 2010 - 03:42 AM
Is there anywhere to get a krasnogorsk3 converted in the uk ?
#4 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 23 April 2010 - 04:11 AM
Personally, I'd try contacting Les Bosher to see what he says.
I've been happy with the service and adjustment work he's done on both my R16 and NPR.
#5 Duncan Buckley
Duncan Buckley
  • 39 posts
  • United Kingdom
Posted 27 May 2010 - 05:09 PM
I have recently modified my K3 to S16mm (yesterday evening to be precise) and I will be shooting some test footage soon so I hope I can prove that it is an easy task to do. The information is out there on the web and I found the process to be quite easy so long as you face the fact that you might mess up. The camera is super cheap and is perfect to start learning about film. I would recommend going ahead with doing it yourself as it teaches you alot about the guts of the beast.
Hope to post up some footage soon.
#6 Marty Hamrick
Marty Hamrick
  • 543 posts
  • Oshawa, Ontario
Posted 07 November 2010 - 09:53 PM
What's the cause of the vignetting on the right hand side of the frame?
