Using a Hilti on set
#1 Michael Nelson
Michael Nelson
  • 33 posts
  • Steadicam Operator
Posted 17 April 2010 - 04:16 PM
For those of you with a Hilti 4, 40 or 42 how often to you find using it over tape? I can see for long distances it would be used a lot but what about the 10-30 ft range? What about within 10 ft? I've been thinking about purchasing one lately but wanted to get your opinions on using it and how using a Hilti is received on set by others (does it make you look lazy? efficient? something else?)
#2 Matias Nicolas
Matias Nicolas
  • 157 posts
  • Buenos Aires, Argentina
Posted 21 April 2010 - 01:55 PM
Leica DIsto A5 works perfectly , and its very usefull ...!
#3 John Waterman
John Waterman
  • 49 posts
  • Chicago
Posted 23 April 2010 - 08:18 PM
I just upgraded my Disto A3 to a Hilti PD-42. I must say, the peep sight for day exterior work is really great. To answer your question, I use my hard-tape for measurements out to 8' or so, then its Hilti. I have a 50' cloth tape too, but it usually only comes out during the prep or for day exterior work where I can't see the laser dot. Now that I have the peep sight I plan on using the cloth tape very little.
#4 Chris Keth
Posted 23 April 2010 - 10:55 PM
I'm very much the same. I tried to cheap out and bought the fat max laser tape. It's great for interiors but useless for exteriors, so my soft tape comes out when I step outside.
People tend to be very (overly, even) touchy if you get the laser anywhere near their face so if I'm measuring to a person, I'll put the dot on the middle of their collarbone. It measures very, very close to the same as measuring to someone's temple like usual.
As for how using a laser makes you look, I've never had anyone think I was lazy for using it, at least not out loud. Everyone I work with appreciate the speed with which I can grab a mark and get on with blocking. In fact, I was outdoors once and the AD asked once, "why can't you use the pointer thingy? It's faster."
#5 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 10 July 2010 - 09:36 PM
Hard Tape, Soft Tape and Laser Tape all have their own purpose. They are the right tool for most situations but not every situation. Carry all 3 so you are always covered ;)
I use a Fatmax which was $100 and goes to 100'. Ryobi makes one that is the same price (I think) and goes to 200'. Check Home Depot.
#6 Steve McBride
Steve McBride
  • 239 posts
  • New York, NY
Posted 21 July 2010 - 06:22 PM
I know the 1st AC for the last job I was on bought a Hilti before the shoot because he knew he was going to be jammed up in corners and against walls where it would be hard to get a mark from a tape since I was 2nd AC and loader so I wasn't always there to actually run the tape for him. At the end of the shoot he was really glad he had bought it.
#7 jasreckson
jasreckson
  • 4 posts
Posted 24 July 2010 - 12:44 AM
On set Hilti works great, it is durable, reliable and powerful solution to be used on any set. Even you will find fastest and best results with this which you won't find with anything else.
