ARRI 300 and CTB problem
#1 julien doumenjou
julien doumenjou
  • 52 posts
Posted 19 April 2010 - 11:45 AM
just shoot a scene in an office (med-shot) using daylight from window and 2 ARRI 300. There was enough light until I put the CTB on the ARRI (of course I had to do it for color balance). Is it my imagination or Arri 300 is really low using with CTB ? Unless used for close up ?
#2 Jeff Kolada
Jeff Kolada
  • 46 posts
  • Columbus/Athens, OH
Posted 19 April 2010 - 12:16 PM
full CTB takes a full stop of light away from anything you put it in front of. So usually if you're going to CTB a light, it should be twice as bright as you would have it without a filter, or closer to the subject.
I am assuming you're using full CTB.
FullCTB: 1 Stop Loss
HalfCTB: 3/4 Stop Loss
QrtrCTB: 1/2 Stop Loss
#3 Chris Keth
Posted 19 April 2010 - 12:48 PM
Full takes 1-2\3 stops. It felt like the light was low because it was! Your 300W was working as only about a 120 watt fresnel.
#4 julien doumenjou
julien doumenjou
  • 52 posts
Posted 19 April 2010 - 01:07 PM
So I should have used a 650W instead of a 300 ?
#5 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 19 April 2010 - 02:05 PM
1/2 CTB would bring the color temp close enough, full CTB actually over-corrects.
#6 Brian Drysdale
  • 5198 posts
Posted 19 April 2010 - 04:06 PM
Full CTB is, perhaps a little under a full correction to daylight, but close enough. 1/2 CTB is no where near a full correction to daylight. I know people use it, but it's a compromise for light output.
On the over correction front, it's full CTO that over corrects converting daylight to tungsten.
#7 Chris Keth
Posted 19 April 2010 - 04:58 PM
If you wanted similar output to the bare 300W, I would have used a baby and then had room to scrim it down if need be.
