Updated Frontbox Plans
15 replies to this topic
#1 Chris Keth
Posted 05 May 2010 - 10:08 PM
Hey, everyone. On a couple days off I updated and slightly cleaned up the frontbox plans I made available a while ago.
It's available a couple of different ways:
-a PDF with three views (view it 100% in adobe acrobat to get rulers) in one document
-adobe illustrator files for the top view, front view, and side view.
It should be pretty evident how everything fits together, but feel free to ask if something isn't clear. I'm not much of a technical draftsman.
PS- I downloaded the files to check and ".ps" was appended on the end of every file and I don't know why. Make sure to remove it. The first file should end in ".pdf" and the illustrator files should end in ".ai"
Edited by Chris Keth, 05 May 2010 - 10:11 PM.
#2 Chris Keth
Posted 03 June 2010 - 07:08 PM
I finally got some time in my father's shop to knock together a frontbox, so I wanted to update this thread with a few photos so it's complete. This is built to the plans I posted above. Cost was about $20 in red oak lumber and 1/8" birch plywood. If I buy it from filmtools, I think the bracket will cost about $50. I will probably make that, too, since they're such a simple bit of hardware.
#3 Dan Collins
Dan Collins
  • 33 posts
Posted 29 October 2010 - 11:22 PM
How did you cut the slots? Is there is a specific tool or technique used?
#4 Chris Keth
Posted 30 October 2010 - 06:47 PM
I used 1/8" thick birch cabinet plywood for the dividers, so a single pass on a tablesaw leaves you with a tight fit. I sanded the dividers to fit snug but not tight.
#5 Kyriacos Mosfiliotis
  • 8 posts
Posted 24 April 2015 - 02:18 AM
pdf not available...can you please update the link?
thanks
#6 Daniel Miler
Daniel Miler
  • 37 posts
  • Tel Aviv, Israel
Posted 21 May 2016 - 12:38 PM
Hi Chris could you please re upload the plans?
#7 JD Hartman
JD Hartman
  • 1808 posts
  • Edison, N.J. U.S.A.
Posted 21 May 2016 - 12:58 PM
He hasn't be active since May 23 2015 12:55 PM.
#8 Gregory Irwin
Gregory Irwin
  • 649 posts
  • Work is based in Los Angeles but I live elsewhere.
Posted 22 May 2016 - 08:49 AM
The main issue here is, the way we shoot pictures these days, front boxes have been rendered obsolete.  We simply don't use them anymore.
G
#9 Phil Rhodes
  • 12406 posts
Posted 23 May 2016 - 11:15 AM
I usually have a little flight case near camera with all that sort of stuff in it.
#10 Daniel Miler
Daniel Miler
  • 37 posts
  • Tel Aviv, Israel
Posted 23 May 2016 - 11:49 AM
Well if anyone else has any clue as to how to get plans for making such a frontbox it would be much appreciated!
I want to make a costumised one before my next project and it would be great to have some plans to rely on..
#11 JD Hartman
JD Hartman
  • 1808 posts
Posted 23 May 2016 - 02:39 PM
There is a software tool that takes and image an superimposes a ruler on the image that can be maneuvered around to measure various features.  Can't remember the name of the application, but I'll hunt around.  Think it was freeware.
Edited by JD Hartman, 23 May 2016 - 02:41 PM.
#12 JD Hartman
JD Hartman
  • 1808 posts
Posted 23 May 2016 - 07:20 PM
This should do it: https://www.imagemeasurement.com/en/
#13 Gregg MacPherson
Gregg MacPherson
  • 2001 posts
  • New Zealand
Posted 23 May 2016 - 09:39 PM
There is an earler thread on this front box. You could contact those guys. Someone probably has the original plans and built one. Or just back engineer it. If some functional dimensions are known, say, as if certain objects normally fit here or there, then you may not need drawings. There's still a photo on the BlackandBlue blog.
#14 Daniel Miler
Daniel Miler
  • 37 posts
  • Tel Aviv, Israel
Posted 26 May 2016 - 01:57 PM
Thanks all
Ill do my best making one, hopefully will update soon with resolts  (:
#15 Michael Maier
Michael Maier
  • 216 posts
Posted 09 May 2018 - 05:14 PM
G
How do you mean? What have made front boxes obsolete? I think they are still incredibly useful.
#16 Bruce Greene
Bruce Greene
  • 711 posts
Posted 09 May 2018 - 07:03 PM
G
They drive me nuts when I operate the camera.  I usually ask that they not be used.
