URGENT help needed for film finish project
#1 petersant
petersant
  • 23 posts
Posted 06 May 2010 - 12:04 PM
Hi All,
I have finished editing and sent of the neg to be cut with a cutting list fom FCP. However, the neg cutter wants an EDL not a Cutting list based on the Key numbers. This is where I'm stuck.
Ok so here is what I've done so far.
Shot 16mm @ 24fps
Transfered at 25fps with FLEx files (camera rolls and timecode) plus burn-ins
Inputed FLEx files into Cinema Tools and batch captured in FCP
Conformed the footage to 24 in Cinema Tools
Edited with sequence settings at DV PAL 48kHz - 24
So I managed to output a cutting list from FCP with the Keycode and checked it with the footage. 99% was ok but 1 frame out in 2 of the 140 shots. Now the Neg cutter wants a timecode EDL.
How do I now output timecode EDL?
Was I right to conform to 24 or shall I reconform to 25?
Please, please help this is for my final work on my MA and can't afford to have it go wrong.
Many thanks in advance,
#2 Andres Pardo aka Gral Treegan
  • 176 posts
  • Mexico DF
Posted 25 May 2010 - 08:10 AM
Hi!!
you nedd to gave the neg cutter the following
1- DVD or Qt of the film with visible TC
2- Source EDL
the source edl is a list of all youre cuts in the order that thay were transfred. to export it go to file menu in fcp > export > edl and the choose source mode
