Replicating Candle Light
#1 Joshua Hutt
Joshua Hutt
  • 1 posts
Posted 12 May 2010 - 09:34 AM
Hello I'm currently working on a short film and I am looking to find a way to replicate candle light as cheaply as possible, has anyone got any suggestions or advice on how to do so?
#2 Jeff Kolada
Jeff Kolada
  • 46 posts
  • Columbus/Athens, OH
Posted 12 May 2010 - 11:17 AM
What are you shooting with and how much light do you need?
I would say use a lot of candles, or two-wick candles. That's probably the cheapest way. When shooting to mimic fire/candles, I usually use a constant source as a base 2 stops under key, and use the candle flicker to highlight the image. You could also use a propane stove and crank it up a bit to give a firey effect.
#3 Corno Dario
Corno Dario
  • 6 posts
Posted 14 May 2010 - 08:13 AM
I did it some time ago, i took a fresnel 3200K spot and pointed it into a water basin with an aluminium thin foil on the bottom of it, and then a guy with a stick made the water surface ripple a bit.
The thin foil gave the diffuse light and the ripple gave the right flicker...
Hope it helps
#4 JD Hartman
JD Hartman
  • 1763 posts
  • Edison, N.J. U.S.A.
Posted 14 May 2010 - 09:50 AM
Hope it helps
Basically, candles don't flicker. They have a single flame, fires flicker because it's multiple tongues of flame.
#5 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 15 May 2010 - 03:42 PM
you can work with clear light bulb an dimmer
to dim it down to 2500k and then work with the dimmer to give slight flicker
