cineform or 12bit uncompressed?
#1 ms sojmon
ms sojmon
  • 4 posts
  • Occupation:1st Assistant Camera
Posted 14 May 2010 - 07:40 PM
what is the good recording format in SI2K ! i tried the 12bit format is it is better than cineformraw?
#2 John Brawley
John Brawley
  • 826 posts
  • Gender:Male
  • Occupation:Cinematographer / DP
Posted 15 May 2010 - 02:41 PM
Uncompressed will use a lot more drive space but is better than cineform, which is compressed. Cineform compression however is still very good.
jb
#3 Stephen Price
Stephen Price
  • 84 posts
  • Gender:Male
  • Occupation:Digital Image Technician
Posted 26 June 2010 - 09:38 AM
From the tests I have done, 12-bit uncompressed is superior than Cineform in image quality. Also the recorder/laptop runs much smoother than when recording to Cineform because no compression is needed.
Correct me if I'm wrong, Cineform is 10-bit Log and Uncompressed 12-bit is Linear. I have not done a latitude test between the two, but I doubt there is much in it.
My main problem with uncompressed is that there is very little that supports it. Iridas supposedly does, but no version of Speedgrade DI I have had has. And yes it will use more storage space, but that is not much of an issue, as long as the image is considerably better.
Steve Price
Digital Camera Technician
London
#4 Phil Rhodes
  • 8379 posts
  • Gender:Male
  • Occupation:Other
Posted 26 June 2010 - 12:22 PM
Depends what you mean by "supports", and what you want to do with what.
There's about 101 types of "Uncompressed".
#5 Stephen Price
Stephen Price
  • 84 posts
  • Gender:Male
Posted 27 June 2010 - 01:27 AM
Generally it would mean a software which can natively work with a particular file format. One which can pick up its meta data and allow manipulation of its RAW attributes and allow transcoding and de-bayering. I have not found any other software apart form Iridas Speedgrade which can do this for 12-bit siv files.
Steve Price
London
#6 Phil Rhodes
  • 8379 posts
  • Gender:Male
  • Occupation:Other
Posted 27 June 2010 - 06:20 AM
This is one reason I'm particularly cautious about this growing trend of every camera system producing a file format that's only compatible with custom tools, or with a few tools of favoured partners. It's very bad news from a workflow-flexibility point of view, as well as an inevitable problem with archiving. SI+Cineform is probably one of the smoothest approaches I've seen, as it plugs you straight into anything that has AVI support - and even that worries me.
Personally I think it's plain as day that these things should output DPX files; there may be a need to do compressed, in which case JPEG-2000 is the most obvious answer. I hate to see every new camera creating this whole problem anew.
#7 Stephen Price
Stephen Price
  • 84 posts
  • Gender:Male
Posted 27 June 2010 - 11:38 AM
Well said
