circle of confusion - IMAX / RED
#1 sarah cuming
sarah cuming
Posted 19 May 2010 - 06:57 AM
Am pulling focus on RED one cam, at 4k. This film may end up blown up to IMAX . Does any one know what Circle of Confusion I should work to?
I generally use PCAm on the i-phone, but its at the menders!
Sarah
#2 Chris Keth
Posted 19 May 2010 - 11:37 AM
Sarah
I normally work 4k red to a CoC of .00075". Since you may be going to imax, you might go a bit tighter to .0005".
#3 Chris Durham
Chris Durham
  • 290 posts
  • New York, NY
Posted 04 August 2010 - 01:37 PM
Hey Chris, I'm just wondering why you use .00075" for 4K as opposed to .001" which I believe a lot of people use for S35. If I understand correctly resolution shouldn't have so much to do with things as format with consideration also given to projection (which is why I could see giving a smaller circle of confusion for IMAX which, but for the larger projection, should have a larger acceptable CoC). Is it to accommodate for pixel pitch? Just wondering. I use smaller than .001" myself but that's basically to make sure my calculations are conservative.
#4 John Sprung
John Sprung
  • 4635 posts
Posted 04 August 2010 - 02:24 PM
The important thing here is that Circle of Confusion is a subjective decision -- there's no absolute right answer. So, the right approach is to shoot a diagonal newspaper test and look at it real big on a good 4K projector. Ideally, the DP would look at that test and make the decision.
