Pulling 7219
#1 Nick Centera
Nick Centera
  • 88 posts
  • 2nd Assistant Camera
  • San Diego
Posted 23 May 2010 - 12:45 PM
Hey, I am going to do some testing on the kodak 7219 stock and I am going to shoot outdoors during the day without an ND then pull it down a few stops. Has anyone had any success doing this? I know that in the interrogation sequence in the The Dark Knight that Wally Pfister did this. I am also looking to bleach bypass the film too. Any suggestions or advice? Thank you
  • 20073 posts
Posted 23 May 2010 - 03:29 PM
Since a bleach-bypass process when done to the negative adds a lot of density -- as if you overexposed by more than a stop -- most people compensate by underexposing (rating faster). A few compensate by pull-processing as a form of density reduction. This also "mellows" the big increase in contrast from the bleach-bypass. "Munich" did this for a few scenes.
But you sort of end up back where you started in terms of speed -- i.e. you end up rating the 500T stock at 500 ASA and asking for a one-stop pull with the skip-bleach. This way you are subtracting one-stop of density in processing, which partially counteracts the more-than-1-stop increase in density from leaving all that silver in the image.
This all gets rather expensive. Plus not all labs offer a pull-process for 16mm, just push-processing.
#3 Nick Centera
Nick Centera
  • 88 posts
  • San Diego
Posted 23 May 2010 - 03:47 PM
My main concern is that when I have taken some basic ratings outside for the 500T I get a F22 or 32, should I get an ND filter just to bring it down? That is why I was asking about pulling the stock.
#4 David Mullen ASC
  • 20073 posts
Posted 23 May 2010 - 06:28 PM
Yes, ND filters are almost as basic as batteries in terms of necessary equipment. The Sunny 16 rule says that in direct midday sunlight on a clear day, your exposure is f/16 if the ASA is the same number as the value under "1/ " for the shutter speed, i.e. 50 ASA at 1/50th, 100 ASA at 1/100th, etc. Since 1/50th is close to the shutter speed for 24 fps filming with a 180 degree shutter angle, you'd be at f/16 on 50 ASA at 24 fps in frontal sunlight on a clear day.
So ND filters are pretty much a given unless you are using 50 ASA filmstock, or live in a country with a lot of overcast weather.
