How is this bullet time-like effect done?
29 replies to this topic
#1 Joe Lotuaco
Joe Lotuaco
  • 71 posts
  • Grip
Posted 31 May 2010 - 07:59 PM
I've been seeing the new promos for all the new shows on TNT and they all have this effect that is similar to Bullet time (ie Matrix). I have also seen a similar effect done where the action will occur normally, then freeze while the actor/objects are suspended in midair while the camera will push in and around actors and then the action resumes without any perceived cuts. One example I can think of was in the first season of Heroes where the character Hero would freeze time and he would move around actors and objects suspended in mid air and then he would restart time during the shot. I know how the effect is done with a large number of digital still cameras, but was wondering if there was another way that the effect is achieved.
At about 0:24
#2 Chris Millar
Chris Millar
  • 1642 posts
Posted 31 May 2010 - 08:53 PM
Looks to me like they could have used bullet time for this bullet time effect - just array them in front then down of each other (with tilt shift if you wanted to get real frisky) then clone them out in post...
But more likely due to the lack of a general downward movement in the shot or general availability of heaps of PC lenses, you have faux 3D here, foreground cop with water is just a freeze fame, as is the guy on the scooter (there is no parallax or foreshortening/perspective change) - the last plate is different in that there is perspective change, but the talent could just hold still for the duration of dolly track (there is no water or other gravity defying elements in that part of the shot), probably shot it overcranked and moved the dolly quite fast to assist... ;)
#3 Rob Vogt
Rob Vogt
  • 437 posts
Posted 31 May 2010 - 10:57 PM
There's no pan or tilt so that makes this shot much easier.
1st pass- 48FPS Have actors stay as still as they can, have wires help support them, like the guys arm which is extended outward.
2nd pass- (frame rate doesn't matter) Blank plate, only atmosphere like the car, setting, No actors.
In post... Take out the wires because of the blank plate you're able to "see behind" them. Add spilling water (3dS Max or Maya) Add Logo. Speed up/slow down as desired.
(^this^ would actually have had better results,- but after watching the video again, Chris is right with his faux 3d theory IMO)
Edited by Rob Vogt, 31 May 2010 - 11:01 PM.
#4 Sanath PC
Sanath PC
  • 1 posts
  • Digital Image Technician
Posted 01 June 2010 - 06:36 AM
Same effect can be achieved very easily with high resolution still image, since characters are frozen. separate each one to different layers and do 3D comp with digital camera move.
#5 Joe Lotuaco
Joe Lotuaco
  • 71 posts
  • Grip
Posted 01 June 2010 - 06:13 PM
Yeah, now that I look at it more, it does look like it could be a still photograph that they extracted the characters out of. But check out the opening and closing shot of this promo for another TNT show. There's a definite perspective change. The last shot where it tracks around the actors does look like it's the typical bullet time shot with a bunch of still cameras rigged in a sequence. But is there another way to achieve this that doesn't involve setting up a bunch of cameras?
TNT Commercial
#6 Chris Millar
Chris Millar
  • 1642 posts
Posted 01 June 2010 - 08:11 PM
TNT Commercial
I dont see any perspective change in the opening bullet-timey bit - just 3D compositing, or 2D and someone is working harder...
Last shot - again, there is no gravity defying water and what not going on - 'talent' (:rolleyes:) just holds still while the camera makes its move, like I mentioned earlier, probably overcranked ... the only trick is the flash, which is added in post... Any movement can also be fixed in post - as simple as that sped up bit if you like, maybe someone blinked :lol:
If we weren't used to/expecting bullet time we'd probably be asking 'why are these people standing still all the time ?' instead...
#7 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 04 June 2010 - 09:31 AM
Agree with previous sentiments. I think it's a combination of filmed camera move with the actors holding positions as best they can plus some CGI work assisting - in order to freeze their movements completely.
There is a bit of parallax happening around the foreground cops elbow which gets revealed as the shot dollies in - but that doesn't say much, as it could be a still frame which they've adjusted so it sits better in 3D space. Or they could be reprojecting select frames from the shot onto 3D geometry or 3D cards in certain areas in order to freeze subtle movements.
There is also something between the cup and his arm, which suggests that it might be part of the rig used to hold the cup which wasn't removed (hard to tell from 480p youtube).
#8 Ray Lavers
Ray Lavers
  • 13 posts
  • Montreal Canada
Posted 17 June 2010 - 02:11 PM
The Faux 3d has an interesting look to it .. How cold I achieve this? meaning what program or plug-in should I use ?. I'm terrible when it comes to 3d studio max. AE , FCP motion is more my jam.
Also if it was done in 2d. It looks as if they did a blank slate because the actors seem to pop out.
Edited by Ray Lavers, 17 June 2010 - 02:13 PM.
#9 Chris Millar
Chris Millar
  • 1642 posts
Posted 17 June 2010 - 03:39 PM
I don't know about motion - but you could always open it up and search the manual for a 3D compositing section
Since you're on a mac (and in Montreal) with the right system specs you could download the Smoke demo from autodesk - it has the Action mode/toolset so it's getting very near to a full Flame in your bedroom ...
Nuke is probably what you'll end up with - Shake .... etc..
oh yeh and AE - but thats not your 'jam' :lol:
#10 Ray Lavers
Ray Lavers
  • 13 posts
  • Montreal Canada
Posted 19 June 2010 - 01:40 PM
I'm pretty good with AE just not 3d studio max. Thanks though.
#11 Chris Millar
Chris Millar
  • 1642 posts
Posted 19 June 2010 - 09:23 PM
3D compositing is a different thing than 3D CGI - so Maya, 3DS Max, Softimage, Houdini etc... don't need to come into at all ;)
#12 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 09 July 2010 - 11:20 AM
Funny, I was just coming to come an make a thread about this technique. As far as the still photograph possibility, I don't think it is. There are other commercials that have perspective switches such as this one where the camera rotates from right to left as it pans.
Edited by Jamie Lewis, 09 July 2010 - 11:25 AM.
#13 Chris Millar
Chris Millar
  • 1642 posts
Posted 09 July 2010 - 03:42 PM
Which is bullet time ...
snore
What technique were you going to make a thread about ?
#14 Jamie Lewis
Jamie Lewis
  • 174 posts
Posted 12 July 2010 - 06:39 AM
snore
Yeah, I believe it is Bullet Time but Joe had suggested it was a single photograph and I was pointing out that it can't be that.
#15 Chris Millar
Chris Millar
  • 1642 posts
Posted 12 July 2010 - 05:52 PM
Read the full thread - he was referring to the earlier spots that had faux bullet time where they (very likely) did use single photographs...
The series of commercials here use a bullet time aesthetic, but use different techniques to achieve it - some real bullet time, some 3D composites with still photography and actor freezes ...
Keeps people off the streets I guess :rolleyes:
#16 Stephen Dickey
Stephen Dickey
  • 1 posts
Posted 03 September 2010 - 12:36 AM
The answer is high speed "Phantom Cam" on a high speed track as the actors keep still for a couple of seconds.
Edited by Stephen Dickey, 03 September 2010 - 12:37 AM.
#17 Chris Millar
Chris Millar
  • 1642 posts
Posted 03 September 2010 - 01:55 AM
post #2
:lol:
#18 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 03 September 2010 - 02:48 PM
That's the Phantom HD Gold, and I believe it came from Abel Cine for the shoot.
#19 alfredoparra
alfredoparra
  • 177 posts
Posted 19 September 2010 - 12:14 PM
after effects check out videoCopilot.com
#20 Adam Hunt
Adam Hunt
  • 154 posts
Posted 04 October 2010 - 12:42 PM
These are definately 2D stills composited in 3D space. It's commonly called 2.5D. You take a 2D image and give it movement in 3D space. Its like sticking some cardboard cutouts in your screen and then moving the camera past them. Really really simple.
There is zero paralax in that promo, so it's not a bullet time rig or any kind of high speed camera trick. It's just 2.5D.
In fact in this case it looks to me like they are actually promo stills that were not originally shot with this in mind. They just cut them out and composited them into a moving shot of the background.
