Camera Technique - How do I execute this?
#1 Jalen Coleman
Jalen Coleman
  • 8 posts
Posted 03 June 2010 - 10:33 PM
Hey Im trying to do a scary film but theres this scene where a kid is walking through the hallway but is dreaming and he sees an illusion of himself chasing this girl. How can I keep the kid in the frame and have him as an illusion. Did I make that clear?
#2 Will Earl
Will Earl
  • 385 posts
  • Wellington, NZ
Posted 06 June 2010 - 01:43 PM
There are a few ways you could do this. The simplest method is to do a split screen - stick the camera on a tripod, shoot the shot of kid watching himself, then with the camera in the same position shoot the shot with the kid chasing the girl. In the edit lay the two shots on top of each other and use a split screen effect (or mask, depending on your editing program) to split the shot in two.
There are a bunch of how-to videos on youtube which describe how to create the effect using a variety of software programs...
You can get quite complicated with how the line is defined so it doesn't have to be a straight line and if you can also use rotoscoping to animate the line for more advanced effects.
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 06 June 2010 - 03:28 PM
It could also be done with a double exposure. Shoot the boy walking down the hall and seeing himself chasing her at the end of the hall as a double exposure. Careful blocking and lighting will help to sell it.
I can't think of a good example right now but this sort of gag was used by Hollywood in the 1930's for dream and fantasy scenes.
#4 Robert Costello
Robert Costello
  • 62 posts
Posted 07 June 2010 - 07:00 AM
Melies movies are worth studying-
they have a lot of simple but convincing effects-
#5 Jalen Coleman
Jalen Coleman
  • 8 posts
Posted 07 June 2010 - 01:08 PM
Thanks!
#6 Jose Luis Juarez
Jose Luis Juarez
  • 1 posts
Posted 27 May 2011 - 02:42 PM
alo everyone...(=
Im new here but im jose...(= i was wandering about the splitscreen subject, the situation is this, I shoot in 35mm, but I have no possibility of making DI, so i must recur to oldschool methods, but i dont know exactly how to do it in the simplest way possible.
Im shooting in ARRI 2c...small and lightweight for a bulletproof camera...(=
Dzeki so much....(=
#7 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 06 June 2011 - 10:51 PM
alo everyone...(=
Dzeki so much....(=
By split screen, do you mean filming the same subject in two areas of the same frame, as in the above example? With your 35mm Arri, you could consider running the film twice through the camera. So basically you shoot your subject doing whatever, and then rewind the film and shoot your subject again (who is now on the opposite side of the frame.) Always a risk with scratching the film doing this, and you would have to compensate for the exposure. If you expose normally, you would probably overexpose the footage (giving the film twice as much exposure than you normally would.) I know that in the early days, Mitchell cameras were highly regarded for this type of work because of their rock steady registration. I don't know about the Arri...it might be okay for what you want to do.
Or by split screen, do you mean different subject matter in different parts of the frame with a dividing line between them? Hopefully, others can pitch in and share their thoughts.
#8 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 06 June 2011 - 11:03 PM
Edit: I guess a similar thing might work - rewinding the film between shots. You might have to cover one half of the scene with something black for each pass of the film and then alternate. Others with experience at this sort of thing might have some suggestions.
#9 Damien Andre
Damien Andre
  • 65 posts
  • New Joisey
Posted 07 June 2011 - 12:24 AM
is possible to use a double? if hes just running by.
Edited by Damien Andre, 07 June 2011 - 12:25 AM.
