7D and 5D lens size/perspective equivalancies
#1 Morgan Peline
Morgan Peline
  • 417 posts
Posted 19 June 2010 - 06:27 AM
I'm shooting a sitcom on some Canon 7Ds. I am just confirming something. A friend told me that you need to multiply by 1.6 to get lens size equivalencies
e.g.
If I wanted to use a standard lens - a 50mm on a D5 then to get the same perspective of a standard lens, on a D7 I would need to use an 80mm.
Is this right?
Thanks!
#2 Morgan Peline
Morgan Peline
  • 417 posts
Posted 19 June 2010 - 06:56 AM
e.g.
Is this right?
Thanks!
I just found it on the net. So you need to divide by 1.6
So to get a the same 50mm perspective on a D5, for a D7 you need to use a 31mm.
http://www.the-digit...rop-Factor.aspx
Thanks!
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 19 June 2010 - 10:37 AM
Another way to think about it: The 7D sensor is very close in size to a 35mm motion picture frame. If you've shot 35mm just use the focal lengths you're used for given setups.
#4 David Mullen ASC
  • 20073 posts
Posted 19 June 2010 - 11:30 AM
Yes, I'm not sure why one needs to mentally convert everything to 8-perf 35mm (FF35) focal length equivalents if one is used to shooting movies. The focal lengths used for a 7D would be similar to any 35mm cine / Super-35mm / Red One, etc. show; it would only be if I were shooting on the 5D that I would have to calculate what lenses to use!
The 7D's APS-C sensor is roughly 22.5 x 15mm, which is similar to 3-perf 35mm.
#5 Morgan Peline
Morgan Peline
  • 417 posts
Posted 29 June 2010 - 09:19 PM
....I didn't realize....
So a 'Standard lens' on a 7D is a 50mm (or a 40mm depending on your personal taste...) just like on 35mm.
That makes things much easier!
Thanks a lot!
