Covered Wagons or Batten Strips
#1 James Beilharz
James Beilharz
  • 8 posts
  • Melbourne, Australia
Posted 26 June 2010 - 07:04 AM
Just wondering if anyone could point me in the direction of how to make some covered wagons as Roger Deakins calls them?
A basic piece of wood with multiple lights connected in a row then covered with muslin or similar material.
If you had any pictures that would be great.
#2 Aaron Solomon
Aaron Solomon
  • 84 posts
Posted 26 June 2010 - 02:07 PM
What kind of lights are you trying to connect? Where would you be using them?
#3 Stuart Brereton
Stuart Brereton
  • 3346 posts
Posted 26 June 2010 - 04:19 PM
They are really simple to make. Mine are made from 4' lengths of cheap pre-cut pine shelving about 6" wide. Each has 6 ES lamp sockets on it, wired in a parallel circuit. To cover them I use chicken wire stapled to the long sides of the wood and curved into a tube. I then fix the muslin to the wire, and it's done. You can get just about all the bits you need from Home Depot or other hardware store.
#4 David Mullen ASC
  • 20072 posts
Posted 26 June 2010 - 07:13 PM
I've used the cardboard/plastic housing for a 4' 2-bank Kino as the base, then put the batten strip / row of lightbulbs inside that, diffusion around the outside -- that way I could use the Kino base plate for rigging to a gobo head, though it's easy to add a pin or baby spud to the back of a batten strip.
