what is the standard widerange for movies ?
7 replies to this topic
#1 Danielito
Danielito
  • 35 posts
Posted 27 June 2010 - 03:30 PM
I just saw the movie "runaway bride" with julia roberts and richard gere in television playing and I recognised that there weren't any wide lens shots in it. It looks like the whole movie was shot on 50mm or 35mm lenses. Is that the standard range for movies ? I have a zeiss 85mm 1.4 and looking now to buy an additional lens but I can't decide wheter go for the 35mm 2.0 or the 50mm 1.4 for having a standard movie lens.
thanks for your help.
Posted 27 June 2010 - 03:59 PM
When you have enough space to back up the camera, it's mainly a stylistic choice, but if you are going to be shooting in typical locations for an indie movie -- i.e. real apartments, kitchens, bedrooms, bathrooms, or inside moving cars, etc. you are going to need some wide-angle lenses to get wide shots. Certainly a 35mm, 50mm, and 85mm would be a good set for most situations, though occasionally you might want something wider-angle than a 35mm.
#3 Danielito
Danielito
  • 35 posts
Posted 28 June 2010 - 03:39 PM
Hi David, thanks for your reply. I shoot my movie on a canon 5d and it's fullframe sensor. So people told me if I will go wider then 35mm and will pan and tilt indoor then the image will not look natural, it will look more like in a 3D videogame. Is that correct ? Can I ask you what kinda lens do you use on the very big cameras when it concerns indoor shootings
and what is the standard widerange for outdoor shootings ?
#4 David Mullen ASC
Posted 28 June 2010 - 10:10 PM
You should have said that in the first place -- I was quoting 35mm cine / Super-35 / APS-C focal lengths.
There is a 1.5X difference between a 36mm wide sensor (FF35) and a 24mm wide sensor (Super-35). So you use a 75mm lens on a FF35 camera to match the field of view of a 50mm lens on a Super-35 camera.
But even on a FF35 camera, a 28mm is not unusual for wide-angle shots, similar to the 18mm often used in Super-35 for wide-angle shots. But you could probably start with a 35mm on a FF35 camera for your wide-angle shots.
#5 Danielito
Danielito
  • 35 posts
Posted 30 June 2010 - 03:30 PM
Wow that's nice my canon 5d has even a larger sensor then a super 35 cine cam ? mmwahhhh :blink: BTW I am a big fan of jennifers body. May I kindly ask you what camera set up did you use for the two girls bedroom kissing scene ? I think this was just an amazing lowlight shot.
Edited by Danielito, 30 June 2010 - 03:32 PM.
#6 David Mullen ASC
Posted 30 June 2010 - 03:39 PM
The wide shot was toplit by a rectangular chimera with some light bulbs behind it, a rig my gaffer called a "half dome". We cut a slot in the low angled ceiling above the bed to put the light. I added a small 650w zip softlight next to it to add more exposure to their faces when they fall back onto the bed; it faded up during the shot.
Wide shot with stand-ins:
Ceiling above the bed:
Closer shots were lit either with some Chimeras or bounce cards, crosslighting the actresses.
#7 Danielito
Danielito
  • 35 posts
Posted 02 July 2010 - 04:32 PM
that's so cool, cheers
#8 Derick Joe
Derick Joe
  • 1 posts
Posted 25 August 2010 - 10:37 AM
David, how did you light the overall ambiance in the room? It wasn't all from those practical lamps on the bedside tables was it?
