IN-CAMERA CROPPING w/Canon 5D Mark II ??
#1 Bwana George
Bwana George
  • 25 posts
Posted 27 June 2010 - 05:09 PM
If you use DX or similar lenses on a Canon 5D Mark II is there an in-camera menu cropping mode so you can eliminate the vignetting on still images without having to use Photoshop later?
What if you use these same lenses in the video mode? Can you do the in-camera crop for video too ?
Thanks.
#2 Valentin Farkasch
Valentin Farkasch
  • 18 posts
Posted 27 June 2010 - 06:16 PM
i am pretty sure that on the 5D there is no way in camera to crop the image.
maybe in photomode but in video definetly not.
#3 David Mullen ASC
Posted 27 June 2010 - 07:49 PM
There is a little bit of cropping in HD mode (mostly top & bottom) because HD is 16:9 and the sensor is 3:2.
#4 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 08 September 2010 - 03:34 PM
I'm curious - someone told me that on the 5D & 7D, when you shoot video instead of still shots, that it IS cropping: that it's only taking the middle of the chip as the HD image (the middle 1920 pixels, etc.), not using the full sensor & downsizing like I thought it was.
Which is correct?
Matt Pacini
#5 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 12 September 2010 - 10:13 PM
It uses line skipping, pixel binning and downsampling to derive the 1920x1080. If it really took just the center of the image then it would not have the shallow depth of field look so many people like from these cameras.
#6 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 17 September 2010 - 05:02 PM
Now I know.
bhphotovideo.com has an excellent slideshow on the features and drawbacks (there are many!) of the HD-DSLR cameras.
It points out how you can get moire patterns, because the camera is grabbing pixels from a grid, not using the whole sensor, then downsizing later.
Matt Pacini
