intermittent mechanisms
#1 Mat Fleming
Mat Fleming
  • 26 posts
Posted 12 July 2010 - 01:51 PM
Hello, I am a projectionist and a filmmaker and i was wondering if anyone can answer a question I've been pondering. Why do projectors have maltese cross intermittent mechanisms while cameras tend to have claws?
Is it purely a question of size and weight or is there something else?
I'm interested because I've always wondered, but also because I'm looking at constructing a camera for a project I'm doing, possibly out of parts of an old projector mechanism. Does anyone know of any resources out there which might help me?
Cheers
Mat Fleming.
#2 Robert Costello
Robert Costello
  • 62 posts
Posted 13 July 2010 - 07:51 AM
It might have been a patent issue-
from wiki:
The first uses of the Geneva drive in film projectors go back to 1896 to the projectors of Oskar Messter and Max Gliewe and the Teatrograph of Robert William Paul. Previous projectors, including Thomas Armat's projector, marketed by Edison as the Vitascope, had used a "beater mechanism", invented by Georges DemenĂ¿ in 1893, to achieve intermittent film transport.
I think if you research any of these names you will get closer to your answer-
Maybe the design was a more reliable one, when there were so many that were not-
http://www.victorian-cinema.net/
is a great place to start-
it has a great bibliography-
and a lot of the technical information and drawings for
the early cameras is still available-
#3 Robert Costello
Robert Costello
  • 62 posts
Posted 13 July 2010 - 08:45 AM
"An important part of the design was that the cross/sprocket (and therefore film) were locked in between movements, ensuring a steady projection of each static frame. "
http://www.victorian...et/features.htm
#4 Robert Costello
Robert Costello
  • 62 posts
Posted 13 July 2010 - 12:58 PM
Practical Cinematography and Its Applications (1913)
by Frederick A. Talbot
"The mechanism of the modern cinematograph
camera is very simple in its character and very
easy to understand. The necessary parts are
very few in number. In all cameras the chief
object is to effect the forward intermittent movement
of the film at regular intervals and for a
defined distance. For this purpose the early
types of camera were fitted with what is known
as the Geneva stop movement. Opinion is
divided upon its merits, some authorities condemning
it unequivocably, while others uphold
it strenuously, contending that it gives a steadier
and freer motion. There is much to be said in
favour of the latter view. Mechanically the
Geneva stop movement is perfect.
So far as
cinematography is concerned its advantages were
proved most emphatically by Mr. Robert Paul,
the first man to bring motion pictures into commercial
application in Great Britain. He adopted
this movement in his camera, and it cannot be
denied that his pictures were in every way equal
to those produced to-day, while his camera has
never been excelled. Curiously enough, although
this movement has been superseded, there is a
tendency among expert workers to revive it,
and many cameras specially built have been fitted
with it.
The movement more commonly used is that
known as the "claw." It is simple, and has the
advantage of bringing the film into place for an
exposure with a sharp, quick jerk. But it is a movement
which requires to be designed very finely
in order to perform its work smoothly and evenly,
and without inflicting any injury upon the film."
#5 Dom Jaeger
Dom Jaeger
  • 1734 posts
  • Melbourne, Australia
Posted 13 July 2010 - 09:04 PM
I would imagine that a claw movement, with its eliptical travel designed to enter, pull down and exit the film perf at more or less the same angle, would be less damaging to the perf than a geneva movement, which would enter at one angle, swivel as it pulls down, and exit at a different angle.
#6 John Sprung
John Sprung
  • 4635 posts
Posted 14 July 2010 - 08:40 PM
The Geneva movement is a mechanism that drives a sprocket intermittently. It's extremely noisy compared with the various claw pulldown designs. It's used on projectors and on the old upright Moviola editing machines. Because it drives a sprocket with several teeth engaged on both sides of the film, it's relatively gentle on the film. But the Geneva pulls down rapidly, in 90 degrees or less. Cameras usually use shutters of 180 degrees or thereabouts, and they don't need to pull the film that quickly. The slower claw pulldown makes less noise.
#7 Mat Fleming
Mat Fleming
  • 26 posts
Posted 19 July 2010 - 10:55 AM
Hello,
Thanks for all your responses and the links to interesting reads. I've been away a few days so I have only read them all just now. I love the elegance of the Geneva movement/Maltese cross but it's true they can be really noisy.
thanks again
Mat
#8 Robert Costello
Robert Costello
  • 62 posts
Posted 19 July 2010 - 11:40 AM
Would camera noise be an issue in the silent days?
Unless the aim was to film more naturally with less noise distractions in
say slice of life or travelogue films- but I can't see that as being a concern in the
early days-
It would seem that the quiter mechanism would be a greater advantage during exhibition, where
music and narration was common-
and all this is assuming that by at least 1913 the Geneva cross was only in special built cameras-
#9 John Sprung
John Sprung
  • 4635 posts
Posted 19 July 2010 - 01:49 PM
For exhibition, Geneva pulldown projectors are used in well insulated booths to control the noise. For portable in-the-room projectors, mostly 16mm, they go with a claw pulldown.
As for early cameras, a simple bell crank and guide slot pulldown is a bunch easier and cheaper to make than a Geneva. Noise wouldn't be the deciding factor.
