Eumig Super 8 Mark-8 Projector
#1 rob dennis
rob dennis
  • 7 posts
Posted 18 July 2010 - 02:27 PM
I have a Eumig Super 8 Mark-8 projector which worked in the UK on 220V. I have just unpacked it from my moving box this morning after 4 years in the USA and the film feed is not moving.
I am using a power adapter which works with my camcorder and other devices. The power and projector light comes on but when I tried to feed the film, nothing moves. HELP!
Also, I would like to know if I can get a digital english manual sent to me so I can understand the purpose for all the knobs and levers.
I'm a newbie to super 8 with a number of films I would like to transfer to digital format. Can I just video the projection? Is that the best way?
HELP!
#2 rob dennis
rob dennis
  • 7 posts
Posted 20 July 2010 - 08:59 AM
Any ideas guys on the questions above?
...if the projector works, what's the best workflow to get the 8mm film transferred to a digital format for future editing?
#3 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 20 July 2010 - 11:06 AM
A likely candidate is a broken drivebelt. I replaced one on eBay a while back. Take the back off and it should be fairly obvious if one is missing. The remains will probably still be in there.
Ah, here you go.
http://shop.ebay.co....rivebelt&_rdc=1
#4 rob dennis
rob dennis
  • 7 posts
Posted 23 July 2010 - 11:57 AM
Ah, here you go.
Thanks Mark.
...No broken drive belt or remains in there. The lamp and power light is on but the feeder is still not working.
Is there another machine I can get to transfer to digital for future editing?EumigMarkS2a2_back_low res.jpg
#5 Antti Näyhä
Antti Näyhä
  • 153 posts
  • Belgium/Finland
Posted 23 July 2010 - 01:28 PM
Hi Rob,
have you tried attaching the red connector in the picture to "200"?
I have one of those Mark 8's, and it seems to be quite picky about correct voltage setting. The voltage here is 230 V, and my projector won't start when set to 240 V (even though most other devices work fine when set up like that).
It might just be that your converter's output is not quite 220 volts, in which case the motor wouldn't run when set to expect that amount of voltage. But try my suggestion on your own risk; I guess you will risk damaging the power supply.
Regarding transferring Super 8 to Digital: you can certainly project the film and shoot it off the screen with a video camera, but this doesn't give you the best possible quality. Dedicated telecine machines / scanners are recommended instead. There are plenty of such services in the US, and some of them quite affordable; you will surely find some recommendations by searching this forum and others like it.
#6 rob dennis
rob dennis
  • 7 posts
Posted 24 July 2010 - 01:44 PM
Hi Rob,
Thanks Antti.
I have connected with 200v and the rest but still no joy...still not sure what the problem is. Perhaps need a better transformer/adapter.
Thanks for the tip on telecine machines / scanners.
Comments from others are also welcomed.
#7 rob dennis
rob dennis
  • 7 posts
Posted 31 July 2010 - 12:12 AM
Thanks Antti.
...Any additional comments as what the problem could be? Thanks.
#8 rob dennis
rob dennis
  • 7 posts
Posted 18 September 2010 - 11:38 PM
The Summer is over. Time to re-start my Project...
...Any additional comments as to the reason why this projector is not working?
#9 Simon Wyss
Simon Wyss
  • 1497 posts
  • Basel, Switzerland
Posted 19 September 2010 - 04:39 AM
What is the mains tension in your place now? We have 233 Volt here. They constantly increase the tension in order to be able to do further investments and to help the supply industries sell their stuff, you know, new sort of bulbs, and the like.
The lamp in your Mark 8 projector is a 100 Watt one. The motor draws 80 Watt. Seems that your adaptor is way too weak for the total of 180 Watt.
