HVX200 - Film Cam mode vs. Video cam mode
#1 Dustan Lewis McBain
Dustan Lewis McBain
  • 53 posts
Posted 18 July 2010 - 04:15 PM
In trying to figure out which scene file to use, one of my options is Film Cam or Video Cam? what does what? Thank you!
Also- Does syncro scan have anything to do with Shutter speed?
Thanks-
Dustan Lewis McBain
#2 Corey Steib
Corey Steib
  • 24 posts
  • Orlando, FL
Posted 22 July 2010 - 02:25 PM
I don't understand your question as far as what your asking. hvx200 does not have a fimgamma setting like the hpx300,370 and up unless your talking about shooting in 24p.And syncro scan allows to you move your shutter to a specific speed that you want (180 degree for film) is 1/48 for video.
Thanks-
Dustan Lewis McBain
#3 Dustan Lewis McBain
Dustan Lewis McBain
  • 53 posts
Posted 25 July 2010 - 11:17 AM
In the scene files on the hvx you have a choice to go with film cam or video, I was wondering what each option does?
#4 Joe Walker
Joe Walker
  • 82 posts
  • Birmingham, AL
Posted 25 July 2010 - 10:36 PM
Film Camera mode allows the shutter to be read out in degrees as well as fractions, ie 1/48th or 180 degrees. It also allows you to access the variable frame rates in the 720p 24pn mode. That's really the only difference between Film Cam mode and Video Cam mode. In video cam mode, you cannot access the variable frame rates in 720p 24pn, they're locked to 24 I believe (or 30, or 60 depending on your recording mode setup). Also in video cam mode, shutter is only read out in fractions, the degrees option doesn't apply. Make sure when shooting off speeds in the 720p 24pn mode that you leave the shutter mode set to degrees so that the "shutter" will auto track to the frame rate.
