Best way to wrap feeder cable?
13 replies to this topic
#1 Salil Sundresh
Salil Sundresh
  • 101 posts
  • 2nd Assistant Camera
Posted 19 July 2010 - 07:53 AM
What's the best way to coil feeder cable?
#2 John Sprung
John Sprung
  • 4635 posts
Posted 19 July 2010 - 02:32 PM
Big heavy stuff like 50 Ft. 4/0? -- Over under it flat on the deck, tie it off and then pick it up.
#3 Ryan Thomas
Ryan Thomas
  • 85 posts
  • Grip
  • San Francisco
Posted 20 July 2010 - 01:57 AM
Yeah, it depends on what you're wrapping.
At a certain point, you'll realize it's too heavy to hold in your hands. So then if you just lay it down flat, find the middle, then wrap it clockwise...once you finish one side, flip it over and do the other. This way you aren't pulling the entire length of the cable every time you wrap it. Makes life easier...
#4 timHealy
timHealy
  • 1262 posts
Posted 24 July 2010 - 11:36 PM
let someone else do it :)
#5 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 25 July 2010 - 12:23 AM
Why over under as opposed to over over?
#6 Salil Sundresh
Salil Sundresh
  • 101 posts
Posted 25 July 2010 - 12:24 AM
Okay well what's the best way to tell someone ELSE to wrap it. haha
#7 John Sprung
John Sprung
  • 4635 posts
Posted 25 July 2010 - 04:06 AM
So as not to introduce twist into the cable. Every loop you make puts a 180 degree twist onto the line. Over under alternates the direction of the twists, so they cancel. This reduces tangling and makes the cable lie flat when you uncoil it.
#8 Alexander Smith
Alexander Smith
  • 6 posts
Posted 25 July 2010 - 10:47 AM
This is true, however on sets over here I've seen people get yelled at for using it on stingers and poop. Even though the set lighting technicians handbook says to use the over under method. Sigh, people always think their way is the only way, so I just always over-over it and twist it counter-clockwise when uncoiling it to remove the butts.
#9 Adrian Sierkowski
  • 7375 posts
Posted 25 July 2010 - 11:02 AM
I'm partial to the quarter hand twist myself.. .though won't work with feeder cable ;)
Over Under is the correct way-- if someone tells you otherwise-- and it's not your cable-- maybe forget it--- but in truth one shouldn't perpetuate bad wrapping...
#10 timHealy
timHealy
  • 1262 posts
Posted 25 July 2010 - 03:00 PM
I don't know a single person who does under over for any electrical cable. The video video and sound guys do but their cable has no relative weight.
Over over works fine as long as the kinks are being twisted out as u wrap and lay the cable into a bundle in it's natural wind. When laying out the twist comes out naturally. But use what ever works for you.
Best
Tim
#11 John Sprung
John Sprung
  • 4635 posts
Posted 26 July 2010 - 08:00 PM
Jeez -- I coil everything over/under, even at home. It's a habit, I wouldn't do it any other way.
#12 Steve London
Steve London
  • 50 posts
Posted 31 July 2010 - 12:18 PM
Best
Tim
I do it over over too but I'm curious about the "twist comes out naturally." If you lay the coil down and pull one end it puts loops into it. You would have to hold the coil vertically and feed it out by rotating the loop to get the cable to lay out flat with no loops. No? Am I doing something wrong?
#13 Tim O'Connor
Tim O'Connor
  • 860 posts
  • Boston, Massachusetts
Posted 01 August 2010 - 09:30 AM
I always do over/under and then it comes out straight no matter who uses it and uncoils it next.
#14 Michael Morlan
Michael Morlan
  • 212 posts
  • Austin, Texas
Posted 08 August 2010 - 11:25 AM
I have heard various philosophies on the matter:
feeder cables - over/under flat on ground
stingers 25-50ft - over/under - keeps collective twist out, down side: knots if you pull the end out the wrong side of wrap
stingers 25-50ft - over/over - matches the internal winding of the conductors, very fast to wrap, lays out well enough. hmm...
The best response I heard to the question about stingers was "If it's yours over/under, if it's a rental, over/over." :-)
Also, when running a stinger, start at the power end, drop a loop near the distro box, and pay out cable as you walk towards the load. Drop excess loop near load with end paying out the top.
Michael
