Right Diameter UV filter and Still Vignetting?
#1 Claus Harding
Claus Harding
  • 65 posts
Posted 03 August 2010 - 04:44 AM
Hi All,
I just got my test rolls back from scanning, shot with my Nizo Pro and Leicina Special, and while they look good, I see vignetting on both cameras in full wide mode; something I didn't see in the viewfinder
Both cameras have the same filter diameter, and I used two UV filters of the same brand, yet I am still getting them "in the shot"....The lens shades used are original Nizo and Leitz ones.
The question is, can I thread a bigger filter on (step-up ring?) or is there a specific UV filter anyone recommends that is wide enough not to interfere?
Thank You,
Claus.
#2 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 03 August 2010 - 06:11 AM
Have you tried filming without any filter on the lens, just to confirm the problem does lie with the filters and not that it's just the lens that's vignetting?
#3 Claus Harding
Claus Harding
  • 65 posts
Posted 03 August 2010 - 11:09 PM
Ian,
That is definitely the next step as soon as I get more film. I just find it hard to believe that both cameras, with two top lenses on them, will do exactly the same thing (but hey...you never know.)
Best,
Claus.
#4 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 04 August 2010 - 02:00 AM
Besides trying a step-up ring, it is also possible to get purpose built thin filters for use on wide-angle lenses. This example is probably in the wrong country for you, but I'm sure a search around might find a local supplier.
#5 Claus Harding
Claus Harding
  • 65 posts
Posted 04 August 2010 - 09:36 AM
Ian,
Thank you for that; I didn't know about the thin filter models. If it turns out the filter thickness is the problem, I'll definitely look into those B&W filters,
Claus.
#6 Glenn Brady
Glenn Brady
  • 328 posts
Posted 06 August 2010 - 08:53 AM
The Schneider-Kreuznach 6-66mm f/1.8 Optivaron lens of the Leicina Special differs optically from the version supplied with Beaulieu 4008 series cameras, but it's physically similar. The Schneider Nr. 30/2 split lenshood designed for that lens (and ordinarily included as an accessory with Beaulieu 4008 series cameras) accommodates series 8.5 filters in an interior compartment. It'll vignette if attached to a threaded filter screwed to the lens.
#7 Claus Harding
Claus Harding
  • 65 posts
Posted 06 August 2010 - 05:59 PM
Glenn,
Thank You! It seems we have solved at least the issue with the Leicina. I did not know this about the lens.
Now I will just have to test run the Nizo "with/without" to see what to do about that one.
Claus.
