I wonder that 5D mark2 & PL mount.
15 replies to this topic
#1 Donghyug kim
Donghyug kim
  • 4 posts
Posted 11 August 2010 - 12:42 AM
5D mark2 with photo lenses has problem on following focus.
So I want change lense mount to PL mount or Digiprime mount.
where can I get mount adoptor?
I'm in South korea, it's difficult to find that product.
Someone help me!!!!
PS : Plz understand my english.
Edited by Donghyug kim, 11 August 2010 - 12:44 AM.
#2 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 11 August 2010 - 03:49 AM
Someone help me!!!!
You can check information :
http://www.flickr.co...in/photostream/
http://www.flickr.co...N08/4872286412/
sergastr@list.ru
sergastr@yahoo.com
#3 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 11 August 2010 - 03:50 PM
nice
were i can get this adapter?
is it good for all 19-oct lenses?
#4 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 11 August 2010 - 05:54 PM
Olex's mount is for 7D not 5D.
7D is 22.3 x 14.9 mm (APS-C size)
5D is 36.0mm x 24.0mm (35mm Full-frame)
I doubt PL cine lenses would have sufficient coverage for 5D.
Cheers,
Jean-Louis
#5 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
Posted 12 August 2010 - 02:10 AM
Cheers,
Jean-Louis
Thank for note.
The lenses of 35 mm cine cameras have limitation of a frame size:
Normal 35 22x16 mm (anamorphic 22x18.6 mm) or Super 35 - 24,9x18.7 mm.
As of this information, the cinema lenses can't cover of a full-frame photo size 36x24 mm.
#6 Donghyug kim
Donghyug kim
  • 4 posts
Posted 12 August 2010 - 07:11 AM
Thank for note.
So, we don't have any solution for 5D?
#7 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 12 August 2010 - 07:25 AM
The Zeiss Compact primes should work in PL. They're "reworked for cinema use" ZF photo lenses.
#8 Oliver Christoph Kochs
  • 323 posts
  • Film Loader
  • Germany
Posted 12 August 2010 - 07:31 AM
If you want to use all the range PL lenses the 5D2 does not work well. You gotta have a APS-C chip sized camera like the 7D. (Read Olex's comment here).
The 7D is readily available in PL mount from FGV. Have fun.
#9 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Most of the the Carl Zeiss Compact Primes CP.2 are specified to cover 36x24mm.
http://www.zeiss.com/cine
Cheers,
Jean-Louis
#10 Donghyug kim
Donghyug kim
  • 4 posts
Posted 22 August 2010 - 08:07 AM
Cheers,
Jean-Louis
thank you!! I worked with zeiss CP several months ago.
and I'll choose that too.
#11 Rob Vogt
Rob Vogt
  • 437 posts
Posted 22 August 2010 - 10:09 AM
In video mode it's not using 100% of the sensor size so most cine lenses will work with the 5d. According to the Abel Cine tech chart here its 145% of 3 perf super35. Assuming most modern spherical cine lenses can cover 4 perf super its only about 16% larger. Obviously vignetting would be an issue, but not nearly as bad as it seems in this thread.
#12 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 01 September 2010 - 01:24 PM
I'm the one who made that chart.
Modern cine lenses are designed to cover the 28.5mm circle of Super-35 3-perf. Many cover a good bit more than this, up into the mid-thirties. The image circle required for the Canon 5D in HD mode is 41.3mm, which is much larger and most cine lenses do not cover this.
#13 Rob Vogt
Rob Vogt
  • 437 posts
Posted 01 September 2010 - 07:27 PM
Sorry Mitch I thought it was the company... Didn't mean not to give you credit for it.
#14 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 02 September 2010 - 01:05 PM
Not at all -- I work for Abel and it is our company that published the chart.
#15 faozan rizal
faozan rizal
  • 1 posts
Posted 08 December 2010 - 11:12 AM
thx for abel cinetech and the chart..its really help me to understanding the image area on digital cinematography since here in Jakarta I shoot always with 35 mm
#16 gavrosh haxhihyseni
gavrosh haxhihyseni
  • 16 posts
  • Albania
Posted 16 May 2011 - 01:01 PM
Does this PL mount work well also on 60D?
