CANON 5D RAW TIMELAPSE FOR FILM OUT
#1 Ted Chu
Ted Chu
  • 15 posts
Posted 17 August 2010 - 01:39 PM
Comments/practical suggestions on shooting RAW (time lapse only) for theatrical release? Will it match 35mm principal photography shot with an Arriflex/Cooke primes? Thanks.
#2 Phil Holland
Phil Holland
  • 20 posts
Posted 18 August 2010 - 09:00 PM
I've done quite a few timelapses for the big screen.
Here's some tips:
-Use a good lens
-Shoot in Manual Mode
-There's a trick to locking the aperture on Canon lenses by using the "depth of field preview" button on the front of the camera and slightly disengaging the lens. This fixes the aperture and will eliminate any iris variation that would cause flicker.
-Shoot in Camera RAW.
-Process the files with a "linear" curve with as much of the shadow detail visible.
-Don't do much to the contrast or saturation.
If you are concerned about anything really matching, it's a great idea to see a frame of what you are working with. Otherwise this would be enough for a colorist to play with.
In terms of it matching cinema primes, in terms of quality you shouldn't be too worried. However, if you are attempting match say a Cooke 50mm you'll want to shoot with something in the 85mm range to match the field of view.
Hope that helps,
Phil
#3 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 31 August 2010 - 12:30 AM
Phil, can you elaborate on this statement?:
"-There's a trick to locking the aperture on Canon lenses by using the "depth of field preview" button on the front of the camera and slightly disengaging the lens. This fixes the aperture and will eliminate any iris variation that would cause flicker."
What do you mean "disengaging the lens"?
It's not hard to set a lens to manual focus.
What's the purpose of disengaging the lens?
(And how would one do that anyway?)
MP
#4 Matt Pacini
Matt Pacini
  • 1246 posts
Posted 29 September 2010 - 12:10 AM
Just make sure you have it on manual or you will have some terrible strobing!
#5 Anamitra Chakladar
Anamitra Chakladar
  • 4 posts
Posted 09 January 2011 - 03:05 AM
Shoot on camera RAW...and then process it on Lightroom and crop it on the aspect ratio that you will eventually require, convert to JPEGs...and then use Quick Time PRo to lay them one after another...and then export them...you are in business...the file sizes are almost 4k rez...good for Red One.
#6 Phil Rhodes
  • 12161 posts
Posted 09 January 2011 - 04:00 AM
More "quite a lot better than" Red One.
#7 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 09 January 2011 - 06:06 AM
The OP stated that he was intercutting with 35mm, not RED. I know it's hard to believe, but there are still some people NOT shooting on RED. ;)
#8 Scott Larson
Scott Larson
  • 36 posts
  • Portland, OR
Posted 11 January 2011 - 06:08 PM
If you want the aperture in a Canon EF lens to stay at a certain f stop, you can use the DOF preview button to set it to that f stop, and then rotate the lens just enough so the pins on the lens no longer make contact with the camera but not so far that the lens falls out. This means simultaneously pressing the DOF preview and lens release buttons.
I don't know why you would do this. The camera will not expose until the aperture is set correctly.
#9 Dave Blackham
Dave Blackham
Posted 14 May 2011 - 04:22 PM
When you rotate the lens the viewfinder aperture setting displays '00' its about 1m to 2mm rotation, if you turn it too far then the camera display's an error after taking one exposure. if this happens just turn the lens back a bit. I lock it with a small piece of camera tape though it doesn't really need it. Also if its a short zoom 16 35mm lock the zoom ring with camera tape also.
