GOKO TC-301 Telecine take-up won't
#1 Frank Fitzgerald
Frank Fitzgerald
Posted 02 September 2010 - 09:15 PM
I have been given a GOKO TC-301 Telecine [super-8] and, without a manual, am trying to get it working. It can be seen at www.goodlight.net/graphics/GOKO-TC-301.jpg. The machine has a number of issues. To start with:
When I click from "Still" to "Forward," all the visible gears start turning, but the take-up reel remains motionless. Also, when I put it in "Reverse," the supply reel does not move. I have opened up the arms at top/crank handles and see a pulley inside each. They appear to be intact.
1. Is there a switch somewhere to activate the take-up and supply reels? Or is there something else I am overlooking?
#2 Mark Dunn
Mark Dunn
  • 2660 posts
Posted 03 September 2010 - 07:21 AM
You say the pulley is intact, but there may be a broken or slipping belt inside the arms. If broken, superglue may fix it, or you might find replacements on eBay.
The lace looks OK.
#3 Frank Fitzgerald
Frank Fitzgerald
Posted 05 September 2010 - 12:04 AM
I have taken the arm covers off and the pulleys are intact and relatively tight, but the wheels inside the arms are not turning.
#4 Frank Fitzgerald
Frank Fitzgerald
Posted 07 September 2010 - 01:25 PM
Curiously, the plate on the side (see below) says, "TELECINE PLAYER TC-301/302." TC-302 is regular 8mm. I assume this is probably a plate the company just used for either machine. OTOH, the supply reel fits regular 8. I've been advised that the machine simply needs a super-8 adapter on that hub.
Unless it turns out there is some way to get this machine to actually take regular-8, I'd just like to get it working normally to sell.
#5 James Lux
James Lux
  • 1 posts
Posted 20 September 2011 - 03:14 PM
Do you still own the GOKO TC-301? If you would like to sell it, I would be interested in purchasing it as is.
