K-100 Repair
#1 Will Montgomery
Will Montgomery
  • 2070 posts
  • Dallas, TX
Posted 09 September 2010 - 02:32 PM
Anyone known for fixing Kodak K-100 cameras? I think I may have over-wound the camera. It seemed to be running fine but I think I may have wound it a little too much; went up to the top tension and now it will not run.
Camera is in great shape otherwise.
#2 David Leugers
David Leugers
  • 68 posts
Posted 12 September 2010 - 11:29 PM
Will I don't know that much about the K-100, but I have recovered from the same problem with a B+H 70 by using the hand crank to manually run the camera forward a little bit and then the spring motor could do its thing. I seem to recall that the K-100 has an input shaft for a hand crank? Hope it helps.
