Stabilization techniques in moving vehicles
#1 Jeremy M Lundborg
Jeremy M Lundborg
  • 61 posts
Posted 15 September 2010 - 08:46 PM
Arricam Lite on sticks. 75mm lens. Shooting inside a moving school bus. Variable road terrain.
Hoping to make the shot as steady as possible on a very low budget. Consider the DIY version and let me know if you guys have any suggestions.
Thanks!
#2 Mathew Rudenberg
Mathew Rudenberg
  • 252 posts
Posted 15 September 2010 - 10:17 PM
Thanks!
If I want a steady shot inside a vehicle I've found that the best simple approach is to simply firmly strap the tripod or hi hat to the vehicle - it's suspension should take care of the bumps.
If there's a massive amount of vibration you can rent vibration isolation mounts from chapman...
#3 michael best
michael best
  • 30 posts
  • Grip
  • La/SF
Posted 16 September 2010 - 04:18 PM
Thanks!
Just tying down the camera and and sticks should work. And it can be as simple as a ratchet strap straight down to the floor if there is a place to grab the floor. A vibration isolation mount is nice but can costs around $150 to rent.
you could try a bungie cam mount, and that would eat up a lot of the bumbs and shacking, but it gives you a more hand held feel. But you can normaly rent those semi cheap is the road is really bad. But I think you are better off with sticks tied off to the bus.
#4 Peter Chrimes
Peter Chrimes
  • 1 posts
  • Grip
Posted 16 September 2010 - 10:00 PM
Denny Clairmont has a great passive isolator as well...
Might be worth looking at...
Good Luck,
Pete
#5 John David Miller
John David Miller
  • 125 posts
  • Grip
Posted 23 June 2011 - 10:50 PM
Triangulate ratchet straps to the hardware at the base of the seats and get a good lock down on the sticks or bazooka. Rigid pipe or lumber with chain vise-grips is even better (both tension and compression).
Use a vibration isolator if needed.
