Codec errors
7 replies to this topic
#1 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 19 September 2010 - 07:42 AM
Hi guys.
Was ACing on a shoot yesterday night.
RED MX, Build 30. Titled 90 degrees for a portrait shots - shooting a look-book.
And then after third slate started to get "Codec Error". Shooting on hard drives - swap them - same error. Reboot - same error.
Only going to cards solved the problem. But then, while formatting one of them, camera froze. But that's another story. Have to say - usual stuff, unfortunately...
Haven't had time for the logs. Should have, I know. But we were shooting live. London Fashion Week. Unfortunately Live and RED is not the best combination.
Any comments, guys?
What is the "Codec error"? Research mentioned that it's to do with amount of fine detail in shot. is it true?
If it is... it's a bit of a joke, really.
  • 20068 posts
Posted 19 September 2010 - 12:01 PM
Was there loud music with a lot of thumping bass, or a lot of people screaming and cheering, etc.? Vibrations cause the hard drives to drop frames, hence the codec errors. I had the same problem during a pep rally scene in "Stay Cool", had to switch to cards. Basically, I would only use Red RAMs and CF cards now on a Red shoot.
#3 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 19 September 2010 - 12:36 PM
No, no noise at all, really...
David, did you make the decision about using RAM/cards on any Red shoots now?
Also - regards mounting the drive - is it safe to mount it on a side, rather then the usual "almost vertical" behind the camera and horizontally on top?
#4 Phil Rhodes
  • 12161 posts
Posted 19 September 2010 - 12:39 PM
Hard disks in general do not object to running sideways - I'm sitting directly next to a cluster of several that've been running on their edges for the last three years, although I'm not sure if it affects their shock rating.
#5 David Mullen ASC
  • 20068 posts
Posted 19 September 2010 - 01:14 PM
Sure, that's a basic part of my job, putting the package together. I may have a few Red Drives on the package as back-ups or for a "C" camera that comes in on a dialogue scene, but otherwise, I'm always going to make the argument that the primary means of recording should be RAMs and CF cards due to the vibration problems. When I did that Red One-shot police drama pilot in Chicago this spring, it was a no-brainer to avoid Red Drives since we were running around town in cars and whatnot.
#6 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 19 September 2010 - 01:51 PM
Cool, thanks for the info once again!
It's been yet another Red production I've worked on where we run into yet another Red drive problem. Unfortunately this one was a live shoot...
I agree that cards-only should be the default Red set-up. Or ram-only, if budget allows.
Edgar.
#7 Eirik Tyrihjel
Eirik Tyrihjel
  • 59 posts
  • Oslo, Norway
Posted 20 September 2010 - 07:01 AM
Sounds like a bad cable to me, had that problem before, get rid of old cable, use new one.
#8 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 20 September 2010 - 07:33 AM
Cheers, will note this one down.
Only had one cable in the package, unfortunately.
