Chapman Vibration Isolator
7 replies to this topic
#1 Andy_Alderslade
Andy_Alderslade
  • 1055 posts
  • London, UK
Posted 19 September 2010 - 03:34 PM
Hi everyone I have a shoot coming up where I will be filming in an old-people's nursing home with a cast of elderly actors and need to track a fair bit, possibly directly on the carpet with numatic wheels, a grip recommended the Chapman's Vibration Isolator to help with this imperfect situation and I was wondering what the general feeling was about it, what's its limitations are etc.
For example can you use it with a fluid head or only a geared head?
Any general thoughts on it would be great.
Many thanks,
Andy
#2 Stephen Murphy
Stephen Murphy
Posted 19 September 2010 - 03:40 PM
Many thanks,
Andy
It's a great tool that in the right circumstances can be very useful. For best results combine with soft wheels on the dolly. It works best with a geared head but can also be used with a fluid head depending on the shot. Like everything there's a limit to what it can deal with but it can give some very effective results.
#3 Darryl Richard Humber
  • 143 posts
  • Grip
Posted 19 September 2010 - 11:40 PM
Stephen's right. But also remember that it doesn't solve everything. I once told a DP, "It isn't a magic vibration isolator." Incidentally, the Dolly Grip on "Mad Men" does a lot of the work with this setup.
#4 Andy_Alderslade
Andy_Alderslade
  • 1055 posts
  • London, UK
Posted 22 September 2010 - 08:17 AM
Thanks Stephen and Darryl, I can't thank you enough for the advice.
I think I will have to pop into Panavision to check it out!
Cheers,
Andy
#5 John David Miller
John David Miller
  • 125 posts
  • Grip
Posted 23 June 2011 - 09:50 PM
I own the one made by Griptech.
http://griptech.net....od&productId=50
I think it is far superior to Chapmans.
#6 David j Bremner
David j Bremner
  • 1 posts
  • Grip
Posted 06 November 2011 - 04:42 PM
It is hard work to operate a dolly direct on carpet pneumatic wheels will help but with the weight of an cam op and focus puller it is a lot of weight the isolator will help but it will only solve a little, try and get on track where you can if i was you, Dave
#7 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 09 November 2011 - 11:27 AM
Could you use shelving boards??
#8 Drew Verderame
Drew Verderame
  • 1 posts
Posted 11 September 2013 - 07:02 PM
I understand why softer wheels would be better for vibrations, but is there such thing as too soft? Like on an F10, with hot gears, and an Alexa Studio, is there a possability of flat spots that need to be constantly rolled out? I found that the porta glide wheels are more smooth than caterpillars. Thoughts?
