Lens focal length comparison chart anywhere?
7 replies to this topic
#1 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 26 September 2010 - 08:26 AM
I'm going to be shooting some tests with a RED One next week and I'm being asked about lenses. Not used a RED before.
Is there a chart anywhere that compares lens focal lengths for the different capture sizes with traditional film formats?
I grew up using a 35mm SLR, so I still think of 50mm as 'normal'. :lol: So what's the equivalent (the same field of view) for RED 2k, 3k, 4k...?
Cheers! ;)
#2 Robin Herinckx
Robin Herinckx
  • 5 posts
  • Belgium
Posted 26 September 2010 - 12:27 PM
Shooting 4K on the Red equals shooting Super 35 format-wise, 2K would equal Super 16. See the attachment for a comparison between focal lengths for different formats.
Hope this helps.
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 26 September 2010 - 01:55 PM
Watch out for full sensor coverage with older wide angle lenses (no portholing) if using a RED.
There's a report on cml concerning Cooke Speed Panchro 18 & 25mm lenses portholing on a RED, it's not clear if that was with a Mysterium or Mysterium-X sensor.
Image Circle for the following formats are:
Canon 7D = 26.82mm
Academy 35mm = 27.20mm
Red Mysterium = 27.98mm
Silent 35mm = 31.11mm
M-X Sensor = 33.54mm
The M-X is 7-1/2% larger than the Mysterium aperture.
Edited by Hal Smith, 26 September 2010 - 02:14 PM.
#4 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 26 September 2010 - 04:06 PM
Hal,
Yeah, it is an issue with the Cooke Speed Panchro 18 & 25 Serues III lenses, as well as the original Zeiss Super Speed 35mm lenses (the wide angle ones) and some of the other older 35mm wide angle cine lenses.
Hunter Richards just shot some 16:9 footage with my Panchro set on a RED and he said he didn't have an issue with the 18 and 25. Don't know if he was using the Mysterium-X sensor version of the RED camera or not.
I think a good idea is to Test, Test, Test.
Best,
-Tim
#5 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 26 September 2010 - 10:15 PM
I think you may find this helpful.
http://blog.abelcine...mparison-chart/
Hal, I think you have a couple of things wrong in your numbers. The RED One Mysterium-X sensor is the same size as the original Mysterium sensor, or at least the active area of it is the same when it is mounted in that camera. It is on the yet-to-be-released S-35 EPIC that is will be a larger 5K sensor.
#6 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 26 September 2010 - 10:35 PM
Not surprised about the RED numbers, I looked all over RED's website for the specs for the Mysterium-X and had to use dpreview.com's number. In effect a RED ONE underscans the Mysterium-X? I used full frame, not 16X9 numbers as on your chart. Obviously actual aspect ratio within a given aperture effects lens coverage issues. For the record on the Cooke SPII/III coverage, Cooke says they were designed to cover the silent aperture. The portholing may turn out to be telefocal issues.
My current mad hatter project is to get my Angenieux 20-120mm T2.9 on my 7D. Paul Duclos says he can make a native EOS mount that will screw directly on the back of the lens avoiding using a PL mount on the lens and then a PL to EOS adapter on the camera. That lens is reverse telephoto in design, nothing will project into the 7D's mirror area requiring radical modification. Therefore I'd retain all the functions the camera is capable of with manual lenses.
#7 Karel Bata
Karel Bata
  • 487 posts
Posted 27 September 2010 - 04:46 AM
Thanks. Interesting. A few surprises there.
#8 Ram Shani
Ram Shani
  • 735 posts
  • isreal
Posted 07 November 2010 - 02:14 PM
here is nice software by abel tech for FOV
http://www.abelcine.com/fov/
