Reflective light metering at a distance
#1 Alexander McCarron
Alexander McCarron
  • 28 posts
  • Philadelphia area
Posted 09 October 2010 - 11:39 AM
I was looking to invest in a new light meter that would let me take a reading of something like a wall of a building I can't close to.
I don't need anything fancy or new.
Any suggestions?
Alex
#2 K Borowski
K Borowski
  • 3905 posts
Posted 09 October 2010 - 11:50 AM
Well then, at this point you need to get a *spot* meter, a highly specialized, expensive instrument that has a smaller angle of incidence. You can pick up a Nikon F series 35mm camera, with a built in spot meter, for less, but there are ways around needing a spot if you're broke.
Get a guy with a cell phone/walkie, and a light meter to get access to this area, and take a reading. Unless you're shooting a building on another planet, or a top-secret military base (even there you could probably, with the right contacts, get someone on the base to take a reading for you), there's nothing on Earth that you can't get close to.
#3 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 09 October 2010 - 12:30 PM
Or you could just buy a second hand spot meter....
There are many available on ebay. Minolta used to make one, the Model F, or the older model M. Pentax also made one. There are also numerous combined incident and spot meters.
#4 K Borowski
K Borowski
  • 3905 posts
Posted 09 October 2010 - 12:59 PM
I recommended second-hand F-series Nikons as cheaper, as he's obviously on a budget.
I don't own a spot-meter, but I would assume they'd retail for more than $150, even used. . .
Andrew McCarron's words: "I don't need anything fancy [. . .]"
Edited by Karl Borowski, 09 October 2010 - 01:01 PM.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 October 2010 - 02:37 PM
Any suggestions?
Alex
You could take an incident reading from where you are, if your outside the light will not be very different, of just use the sunny F16 rule.
