Effects of Full Frame Cine Lenses + 1/2" Sensor
#1 BenjaminCarey
BenjaminCarey
  • 19 posts
Posted 14 October 2010 - 08:23 AM
So I was planning on shooting this short film with the EX1 and the Letus Ultimate, and to get the best picture, I figured we might as well rent Zeiss compact prime cine lenses.
Does this set-up make optical sense? Or will our images be hopelessly cropped and zoomed in? Say, for example, I put a Full Frame 35mm lens on the Adapter -- what will happen?
If I want to use full frame cine lenses, would I have to use the EX3 with 1/2" Relay Lens for proper results?
#2 BenjaminCarey
BenjaminCarey
  • 19 posts
Posted 14 October 2010 - 08:35 AM
***AND, what are optimal lenses to shoot with if one is using the EX1 and Letus Ultimate?
Thank you!
Edited by BenjaminCarey, 14 October 2010 - 08:36 AM.
#3 Adrian Sierkowski
  • 7373 posts
Posted 14 October 2010 - 08:39 AM
An adapter works by rephotographing. So what happens is the lens projects onto the ground glass of the adapter, and the camera records this projected image. There will be some slight FoV differences, but it won't be horribly cropped etc.
