Gelling the Sun
11 replies to this topic
#1 Geovane Marquez
Geovane Marquez
  • 78 posts
  • 2nd Assistant Camera
Posted 19 October 2010 - 11:13 AM
Any ideas? I would like to gel the sun with a white color. Do 12x12 Gels exists?
#2 Adrian Sierkowski
  • 7375 posts
Posted 19 October 2010 - 11:24 AM
I'm not sure what you mean? They certainly has 12x12 overheads which can be silk or muslin or even black, if that's what you're looking for.
#3 David Mullen ASC
Posted 19 October 2010 - 01:50 PM
What's a "white color"? Wouldn't that be a clear gel?
There are no 12x12 color gels though I'm sure you can try taping one together. However, there are diffusion materials such as grid cloth that can come dyed orange or blue.
#4 Geovane Marquez
Geovane Marquez
  • 78 posts
Posted 19 October 2010 - 04:29 PM
Might have to be color corrected then. I know about the overheads (muslin, silk, and black) but from what David said I guess 12x12 gels don't exist.
What we are trying to do is basically create a whitewash skylight that isolates all colors. Seem's like a cool 1/8 blue gel on a huge HMI + color correction would do the job.
Think of the look as yourself being in the middle of the desert but also in the no-time realm where it's all white and trippy looking.
Edited by Geovane Marquez, 19 October 2010 - 04:32 PM.
#5 Adrian Sierkowski
  • 7375 posts
Posted 19 October 2010 - 04:44 PM
Daylight film should render sunlight, White, perhaps with some blue in there, as would white balancing a digital system.
#6 Zander Kroon
Zander Kroon
  • 37 posts
Posted 19 October 2010 - 07:17 PM
Are you trying to produce shafts of clean, white light? Such as: Posted Image
#7 David Mullen ASC
Posted 19 October 2010 - 08:28 PM
Well, if everything just needs to be shifted towards the cooler, you don't need an overhead gel, you can just time the image cooler.
But if you want to gel the sun in only one area, then you'll probably have to tape together some gel rolls onto a 12x12 frame -- the real problem is going to be noise if any breeze hits that gel.
You may want to look into seeing if some very thin diffusion material (like half soft frost or 1/4 grid cloth) can be dyed.
I've actually wanted to try something like this to get the effect of many Renaissance landscape paintings, like by Raphael or Leonardo -- the foreground subject is in much warmer light than the background (because of the exaggeration of aerial perspective, a trick they had just learned and were overusing perhaps). The effect is almost like those Annie Leibovitz photos taken at dusk with big strobe banks through large soft boxes.
#8 Steve London
Steve London
  • 50 posts
Posted 20 October 2010 - 11:23 AM
Mr. Mullen, as a long time reader and devotee of yours here, there and everywhere, I think you need to collect your thousands of informative and helpful posts together and put them in a book. I would buy it. Thank you for your many contributions to those of us plying the craft and aspiring to excellence.
#9 Tom Jensen
Tom Jensen
  • 1234 posts
  • Dallas, TX
Posted 20 October 2010 - 11:30 AM
One of David's strongest points is that he can explain a complex concept clearly and completely in a manner that most people can understand.
#10 Michelob Fedusenko
Michelob Fedusenko
  • 32 posts
  • Film Loader
  • NYC
Posted 27 October 2010 - 08:14 PM
I tried this effect... taped a 20x20 blue party gell together and white balanced through it. We wanted to make the 'mobsters' in white light and have the area around them in hellish red... It was a BIG hassle that would have been better done in post (if possible). There was a lot of noise from wind and you will need to tie down, adjust, tie down, adjust, tie down adjust.... ect. Also, the effect wasn't quite what we desired.
My suggestion is to test it thoroughly prior to shooting and have plenty of gel to spare. Best of luck and show pictures of the build and final product!
#11 verlon allen
verlon allen
Posted 05 November 2010 - 01:24 AM
Trippy? I take it that shooting this as two elements, and then doing some effects work is out of the question, is that correct?
Edited by verlon allen, 05 November 2010 - 01:26 AM.
#12 John David Miller
John David Miller
  • 125 posts
  • Grip
Posted 24 June 2011 - 01:30 AM
While I do not understand why you want to gel the sun, you can get 12'x overheads that are color dyed for correction but that is usually done with silks or grid cloths.
