Mitchell Mount Dimensions
#1 Boyd Hobbs
Boyd Hobbs
  • 16 posts
Posted 23 October 2010 - 02:50 AM
I'm trying to build a custom mitchell mount into an aluminum plate. Much like this one:
I was looking for the important dimensions. I can't seem to find them anywhere--at least not specific enough to machine with.
I need the:
Insert width & depth
Hole width & depth
Key width
I'm not sure the hole depth is important, but I'm going to assume it is for now.
Any help would be greatly appreciated.
  • 1
#2 Sanjay Sami
Sanjay Sami
  • 258 posts
  • Grip
  • Anywhere they pay me to go
Posted 23 October 2010 - 02:43 PM
Not as specific as you may like, but perhaps something you can begin with.
Took these pics of a hybrid riser.
http://www.steadicam...showtopic=11961
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 24 October 2010 - 09:54 AM
Get in touch with O'Connor, they'll have the dimensions and might take pity on you. Another source might be Ron Dexter.
#4 Dom Jaeger
Dom Jaeger
  • 1732 posts
  • Melbourne, Australia
Posted 24 October 2010 - 09:47 PM
From measurements I've got:
On an O'Connor with a Mitchell base the doughnut shaped part that protrudes and locates the head is 4 1/8" OD and 3 1/4" ID. It extends almost 15/64" from the base.
On Ronford legs the mount has a lip that goes inside the 3 1/4" diameter. The mount you pictured would locate outside the 4 1/8" OD.
So you need the insert diameter to snugly fit 4 1/8" and be slightly deeper than 15/64", maybe 1/4".
The key is 3/8" wide, centred 3" from the base centre.
The hole size on a Ronford legs Mitchell base is about 2 7/8" diameter and about 1/4" deep. It can vary, as long as the lock-off covers the diameter and the depth allows you to get enough thread turns to lock off securely.
  • 1
