Skip Bounce
9 replies to this topic
#1 Dirk Naves
Dirk Naves
  • 7 posts
Posted 03 November 2010 - 08:57 AM
probably a total n00b question, but just wondering what this refers to. in a recent article in AC, this setup is mentioned: "a combination of backlight and skip bounce." I'm not familiar with the term "skip bounce." could anyone help me out with a description of this type of lighting? thanks a lot.
#2 Peter Moretti
Peter Moretti
  • 306 posts
  • Sherman Oaks, CA
Posted 01 January 2011 - 03:35 PM
I just read the same article and have the exact same? Anyone? :)
#3 David Mullen ASC
Posted 01 January 2011 - 05:12 PM
Never heard of it -- don't all bounces technically involve skipping a light off of a surface?
#4 Jake Kerber
Jake Kerber
  • 65 posts
Posted 01 January 2011 - 05:40 PM
I use that term for skipping/bouncing a light off the ground. But me and my gaffer usually say "floor skip," which is a little
more specific.
#5 Mathew Rudenberg
Mathew Rudenberg
  • 252 posts
Posted 01 January 2011 - 05:49 PM
Usually when you shoot a light into a bounce you want the light positioned fairly frontal (to the bounce) so it can full the bounce evenly, thus creating the softest source.
The way I've heard it used, a skip bounce is when you set the light at an extreme angle so the light skips across it rather like skipping a stone across water. Usually this is not optimal because the source is harder and output is often less.
You commonly see this this when using shiny boards to redirect sunlight - if the sun is on the far side of the shiny to the subject you have to skip bounce the sunlight.
#6 Adrian Sierkowski
  • 7373 posts
Posted 01 January 2011 - 11:39 PM
I use the term when bouncing off of a floor, or at mentioned at an extreme angle to "something," normally, though, a wall or floor or off a car or something just "there," to make something work in the most jury rigged way possible...
#7 David Desio
David Desio
  • 204 posts
  • california, USA
Posted 20 January 2011 - 01:04 PM
The sunlight scenario seems most common among gaffers I work with. It's used when the sun is not shining in a direction that a normal direct bounce will do, so the shiny board will be put at an extreme angle and make the sunlight basically turn a corner so to speak. Like say your sun is shining from the west and you are facing east with your shiny board, but your actor is facing south and his dark side is toward camera, camera facing north...Ok I need a diagram...basically it is like skipping a rock, the light throws at an angle, usually from the ground. I'll try and do a diagram...
#8 John Sprung
John Sprung
  • 4635 posts
Posted 20 January 2011 - 01:50 PM
The way I've heard it used, a skip bounce is when you set the light at an extreme angle ....
"Rake" is the term I'm accustomed to hearing for that. For instance, you go up on a roof and rake a light down the wall.
#9 David Desio
David Desio
  • 204 posts
  • california, USA
Posted 20 January 2011 - 02:40 PM
Right, raking a light across a back wall, but skip bounce refers to how the light is bounced not what it is effecting.
Edited by David Desio, 20 January 2011 - 02:41 PM.
#10 J. Lamar King
J. Lamar King
  • 764 posts
Posted 24 January 2011 - 07:14 PM
For some reason skip bounce to me means a bounce from the floor or below the subject. Most specifically, skipping large daylight units like 12K's off of 6 and 8x ultras propped up on apple boxes in front of the unit. Sends a nice ambient. Didn't read the article so don't know if this is what they are referring too or not.
Edited by J. Lamar King, 24 January 2011 - 07:14 PM.
