Infinite white not wide enough
#1 Erik Krogh
Erik Krogh
  • 1 posts
Posted 04 November 2010 - 08:56 AM
I am having a problem with shooting on infinite white.
Close ups and mid shots works perfectly, however the wide shots leaves each of the frame sides without white background due to the inifite roll's width. Is there any easy way to solve this problem?
The actor only moves inside the area of the infinity roll.
#2 Brian Drysdale
  • 5195 posts
Posted 04 November 2010 - 09:09 AM
If you're shooting digitally you should be able to extend the white backdrop in post.
#3 David Mullen ASC
  • 20072 posts
Posted 04 November 2010 - 10:31 AM
You could put a white card on each side of the lens, out-of-focus, to extend the white.
#4 Jed Shepherd
Jed Shepherd
  • 60 posts
Posted 06 November 2010 - 08:35 AM
Garbage matte out the edges. Depending on what program your using you should be able to plug a garbage shape into the garbage matte input of your keyer. If using node based compositor that is. Unless your shooting a white infinite background which then you would still garbage matte out the edges but wouldn't have to go through a keyer necessarily.
#5 Chris Millar
Chris Millar
  • 1642 posts
Posted 06 November 2010 - 05:46 PM
I've done it with black - but white.... Interesting
Assuming the white is blown out ?
Flare issues ?
Either way it could prove fiddly lighting wise huh...
But I'm guessing you've done it previously - I'll stick it in my bank of possibles that 'I've read about on the net' :)
Its all a bit moot with enough time in post however - need more info from the OP
Edited by Chris Millar, 06 November 2010 - 05:47 PM.
#6 David Mullen ASC
  • 20072 posts
Posted 06 November 2010 - 05:58 PM
Flare issues ?
No I haven't done it with white but I've seen that John Seale Kodak lighting demo where he hides a light mounted to a tan wall in the shot with a tan card in front of the lens. So it should be possible with a white background as long as it is evenly white (i.e. fairly blown-out) and there isn't too much depth of field or the shot isn't too wide-angle enough.
#7 Chris Millar
Chris Millar
  • 1642 posts
Posted 06 November 2010 - 07:21 PM
Should note the black version we did wasn't mounted on the camera as it was locked anyway...
Just a flag - noticed the effect was useful when looking through the finder - "hey! no, leave it there in shot, it works!"
A lot of interesting problem solvers to glean from product photography huh ;)
"fix it in pre"
