In need of guidance
#1 Carl Marks
Carl Marks
Posted 09 November 2010 - 10:18 PM
well heres what my end goal is:
im going to set up maybe ten cameras on a stage during a concert.
i want to display the camera angles live feed using the two projectors.
im assuming the bullet cameras are cheaper because i will be using the pc as a DVR instead of ten individual cams.
from running sound, i assume the bullet cams will feed into a interface that has video outs that can be controlled by the pc?
Bullet Cams>>>Interface>>>PC>>>Interface>>>Projectors
am i even close on this one?
i am trying to figure out what i need to accomplish my goal but since i have such little experience in AV,so my questions are:
-what are the best cams for this app?
-does such an interface exist?
-can i control the the different projectors in real time with a pc?
end result,i want to have many cameras set up and be able to switch whats being played on the different projectors in realtime.
#2 Phil Connolly
Phil Connolly
  • 443 posts
Posted 10 November 2010 - 04:07 PM
Hmm not sure there are any PC based Vision mixers that can accommodate 10 cameras at the same time.
This situation would require a dedicated hardware solution eg:
http://www.creativev...alley_indigo-hr
This would allow you to switch between the different cameras and route their signals to the projectors - also to apply simple effects.
You might be able to find a cheaper solution on ebay.
But a 10 camera multi-cam rig could get expensive to do properly as the most the more affordable vision mixers (switchers) only have 4 or 5 inputs - and the larger ones cost more and require genlock. That said you can do a lot with only 4 cameras if you have good camera operators giving a nice range of shots.
