COOKE 20-100 Zoom on RedOne HELP
10 replies to this topic
#1 Sam King
Sam King
  • 2 posts
Posted 14 November 2010 - 08:53 AM
I have a Cooke 20-100 Zoom lens on my RED. At the widest end I get vignetting only down the right side of screen. Shooting wide open at most lengths also has blur only on the right side of the screen. When I stop down to 5.6 the blur goes away.
Would this be an issue with the lens or with the RED? I'm uncertain of how old this lens is and whether that could be a contributing factor.
Any help with this would be much appreciated!
Cheers,
Sam
#2 Sherman Johnson
Sherman Johnson
  • 10 posts
  • Miami / Atlanta, USA
Posted 14 November 2010 - 11:39 AM
Hi Sam,
The Cooke 20-100 was introduced in 1971 and does not fully cover Super-35 (roughly the size of the Red's sensor).
- Sherman
#3 Markus Rave
Markus Rave
  • 103 posts
  • Frankfurt, Germany
Posted 14 November 2010 - 11:56 AM
I had the same lens and there was never an issue with vignetting. At that time there was no 4.5k widescreen area, so I donĀ“t know about that. But with 4k no problem. Is the lens clean on the collimator? Could be a problem there. 20mm should cover S35 if I recall. There will be an issue going wider though. I had a standard prime lens set form Zeiss and the 16mm showed vignetting and the 24mm did not.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 14 November 2010 - 01:32 PM
I have used one for S35 film, it was necessary to take off the fitted matte on the front of the lens. I suspect the lens mount on your camera is not exactly in the middle of the sensor.
Stephen
#5 Sherman Johnson
Sherman Johnson
  • 10 posts
Posted 14 November 2010 - 01:45 PM
I stand corrected...
#6 Dom Jaeger
Dom Jaeger
  • 1734 posts
  • Melbourne, Australia
Posted 14 November 2010 - 06:25 PM
A quick way to check would be to mount the zoom upside-down (if the mount allows). If the vignetting remains on the right side, I would concur with Stephen that the camera mount is probably not correctly centred. Alternatively, mount a lens that you know will vignette and see if the porthole is off-centre.
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 15 November 2010 - 02:40 PM
All the ones I have used have been off, some more than others....
#8 Dom Jaeger
Dom Jaeger
  • 1734 posts
Posted 15 November 2010 - 08:10 PM
Good grief, really? So as well as possible edge shadows every zoom would track off to one side. What dinky cameras.
#9 Sam King
Sam King
  • 2 posts
Posted 16 November 2010 - 07:58 AM
Thanks for all your replies so far.
Stephen, so apart from weird vignetting, have you had that blur on one side of the screen too? Do you think it's the camera? The primes seem fine. But my zoom, yeesh!
What have you done to correct it?
Sam
#10 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 16 November 2010 - 02:46 PM
Sam
S35 is at the absolute limit for most cine zooms, everything must be spot on to work properly, most primes have a bigger image circle so it's less of an issue.
Using a film camera is the quick fix I usually do, failing that check out a few bodies & take the one that works best or just use primes, it's just one of those little issues that many people just ignore & accept. I do know a few cameras that have been sent back to the factory.
#11 John Sprung
John Sprung
  • 4635 posts
Posted 16 November 2010 - 03:30 PM
Based on that, the next step should be to find a good lens shop, and get your zoom properly tuned up. Where are you, perhaps someone will have a local recommendation.
