AF100 with Zeiss Distagon
#1 Jonathan Dube
Jonathan Dube
  • 14 posts
  • Grip
  • Quebec,Canada
Posted 22 November 2010 - 03:51 PM
Hi guys,
I'm wondering about the crop factor question if i'm using S16 Zeiss Distagon on an AF100 with the PL mount adapter..
Anyone?!
Jon
#2 Brian Drysdale
  • 5193 posts
Posted 22 November 2010 - 05:23 PM
If it's a Super 16 lens, there's good chance the image won't cover the sensor. The Super 16 frame is much smaller than the Micro 4/3 used in the AF100, which is closer to motion picture 35mm.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 26 November 2010 - 12:15 AM
Super=16 has an image circle of 14.5mm, while the AF100's sensor ha an image circle greater than 19mm. Most S-16 lenses will not cover.
#4 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 04 December 2010 - 06:01 AM
Obviously The Super 16mm standard wont cover the four thirds sensor but lenses are often made larger than neccesary. I believe this to be right. Someone correct me if I'm wrong but the diameter of the glass on the back of your lens is likely to be how much the sensor will cover. My Zeiss 25mm is 20mm dia for example. Measuring my Zeiss superspeeds I can see that my lenses could cover the sensor except for maybe the 12mm and 9.5mm However I would likely be cropping the frame to 2.35 and missing the corners anyway and if there is some vignetting then you could zoom in or maybe you might like the look and keep it!
Be nice to hear if anyone else has tested the Zeiss superspeeds or 16mm lenses.
Also I can't wait for Jim Jannards Scarlet to come out as this looks set to clean up.
Mark
#5 Brian Drysdale
  • 5193 posts
Posted 04 December 2010 - 07:31 AM
You shouldn't have coverage problems with the Scarlet, it's now only 2/3", all S35 etc are now part of the Epic range at a higher price.
#6 Mark Williams
Mark Williams
  • 811 posts
  • United Kingdom
Posted 04 December 2010 - 10:34 AM
Arrgh Goodbye Scarlet!
