Repairing a C-stand
16 replies to this topic
#1 Thomas Worth
Thomas Worth
  • 372 posts
Posted 25 November 2010 - 05:13 AM
I've got a couple stands that could use some tightening. However, the bolt that holds the base together needs to be held in place from inside so it won't turn when I try to turn the nut on the bottom. How do I hold the head of the bolt? It seems that I'd need a very long socket extension. Any ideas?
#2 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 25 November 2010 - 08:16 AM
Might help, if we knew why type of C-stand and the maufacturer. I'm guessing that this is the "typical" stand with spring loaded legs?
#3 Mark Dunn
Mark Dunn
  • 2667 posts
Posted 25 November 2010 - 12:37 PM
I'm not familiar with C-stands so this may not work, but if you use an adjustable spanner, you can hold the bolt still with pliers or a grip whilst turning the nut. Then, as soon as the bolt head is a bit tight against the tube you can tighten as required.
#4 Dom Jaeger
Dom Jaeger
  • 1732 posts
  • Melbourne, Australia
Posted 25 November 2010 - 07:20 PM
A sharp star washer under the bolt head will allow you to tighten the nut without having to hold the bolt. You just need to get the nut on and tight enough so the washer starts to bite.
#5 Thomas Worth
Thomas Worth
  • 372 posts
Posted 25 November 2010 - 09:24 PM
The problem is the bolt head is inside the main body of the C-stand. If I turn the bottom nut, the bolt itself turns because there is no star / lock washer, etc, at least not on this stand. There's no way to hold the bolt head unless I have something long enough to all the way down the length of the main body/tube (after the telescoping stages are removed).
I attached a diagram that shows how it's put together. This is a Matthews stand, but all Century-style stands share this same design as far as I know.
#6 Dom Jaeger
Dom Jaeger
  • 1732 posts
Posted 25 November 2010 - 10:38 PM
OK, so it's the spring loaded type, held with a nylock nut to stop it undoing when you unfold the legs.
I think you're right, you'll need a long socket handle to hold the bolt head. It's possible that if you just poke a long rod down to compress the bolt head against the spring the friction might be enough to hold it while you tighten the nut. But nylock nuts grip pretty hard.
#7 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 27 November 2010 - 05:26 PM
yes you need a long socket extension to get at the bolt head.
#8 Mark Dunn
Mark Dunn
  • 2667 posts
Posted 28 November 2010 - 07:50 AM
My way might still work if you ditch the nyloc nut and use a plain one. Grip the thread gently with pliers while you tighten the nut. Then when there is some thread protruding below the nut, hang on to that. Perhaps you can reduce the friction with some oil. A star washer on top of the nut might help it bite.
#9 robert duke
robert duke
  • 438 posts
  • Grip
  • southeast USA
Posted 28 November 2010 - 10:14 AM
mark,
your way risks gumming up the threads for future repairs, and turning a Nylock nut esp. one that large is a LOT of torque. More than what you could hold with pliers one handed on a sliver of thread.
#10 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 28 November 2010 - 10:24 AM
Weld a deep well socket on the end of a long piece of steel tubing with a "T" handle welded to the other end. 1/2" EMT (thinwall) conduit would probably work. If you purchased all the materials and cut them yourself, a welding shop would probably knock it together for less than $20, maybe much less (a six pack or dozen Krispy Kreme's would probably get it done for nothing).
Use the mill (factory cut) end for the socket to ensure an exactly square cut for the socket to sit on.
#11 Ed Conley
Ed Conley
  • 90 posts
Posted 01 December 2010 - 02:02 PM
I'll weld it for you for free
I probably have everything 'cept the socket
ed@screamingbroccoli.net
Edited by Ed Conley, 01 December 2010 - 02:03 PM.
#12 JD Hartman
JD Hartman
  • 1764 posts
Posted 06 December 2010 - 10:17 AM
If it were me, I'd take a piece of 5/8 steel rod, grind four flats (3/8, or 1/2" square) to make a tight fit in the socket and drill a cross hole at the other end of the rod for a tommy bar. No welding, no damaging a socket, power drill, angle grinder or bench grinder, done!
#13 Jon Wolding
Jon Wolding
  • 2 posts
  • Tampa
Posted 20 May 2018 - 09:29 PM
I was trying to fix a broken 40" Matthews c-stand (spring-loaded model, legs were frozen up) and I, too, had a problem getting the lock nut off the bottom, so I searched for an answer and came up with this thread.
Although all of these ideas are decent and probably work just fine, I have a stupid simple solution for removing the lock nut:
1. Remove the telescoping sections from the main tube.
2. Get a 3/4" (I think this is the standard nut size for Matthews c-stands) deepish socket and an impact driver (I used a basic 18V Makita, nothing fancy).
3. Pour a few handfuls of copper BBs (or lead shot or maybe small sinkers) into the main tube.
4. Keep the stand vertical and remove the lock nut with the impact driver.
5. Try not to get excited and dump your BBs all over the floor when the nut spins right off.
6. Tilt the stand and pour the BBs into the container they came in (I had a carton) or whatever.
Just reverse these steps to put it back together.
And when the nut is back on, you might have to bang on the tube with a mallet to shake the BBs out... otherwise you'll have a very annoying c-stand maraca.  ;)
#14 Gregg MacPherson
Gregg MacPherson
  • 1933 posts
  • New Zealand
Posted 20 May 2018 - 10:32 PM
These problems come up like little seasonal flowers.  My solution was simple, but worked..
http://www.cinematog...showtopic=65016
Jon Wolding's version sounds interesting, though I can't say I get it.
I like the idea of jamming something into the drive end of a socket.....
#15 JD Hartman
JD Hartman
  • 1764 posts
Posted 21 May 2018 - 09:13 PM
In theory the BBs fill the space between the hex head of the bolt and the interior of the tube, wedging the bolt in place so you can remove the nut.
Edited by JD Hartman, 21 May 2018 - 09:14 PM.
#16 victor huey
victor huey
  • 117 posts
Posted Yesterday, 02:17 AM
Easy way to fix, is take a deep socket wrench and a long 3/8" threaded rod tighten the deep socket with a 3/8" nut in the socket, and then one on the outside effectively making a very long socket extension, i have used this many times to change out the busted spring on the matthews stands.
#17 Gregg MacPherson
Gregg MacPherson
  • 1933 posts
  • New Zealand
Posted Yesterday, 06:37 PM
Victor, that may be the simplest one. But anything that connects the socket to some kind of extension will work.
