What do u call it?how do we use it?
#1 anroop mri
anroop mri
  • 11 posts
Posted 05 December 2010 - 04:34 AM
Hello everyone,can anybody please tell me wht is the pipe like thing which is used by directors on a set ?is it used to to see the frame ,but why that tube if they can directly see from cam viewfinder?what does it do?does it give u the accuracy ,or how do u use it?
#2 Brian Drysdale
  • 5198 posts
Posted 05 December 2010 - 05:16 AM
It's a director's viewfinder. They give an approximate angle of view for a lens and framing for various aspect ratios.
If you need something more accurate there are viewers that allow you to mount a lens from the camera and uses a ground glass with a camera type viewfinder.
The advantage it that it doesn't tie up the camera while angles are being checked. A 35mm camera is pretty heavy, so it's awkward and time consuming to carry this around looking the many possibilities within a scene.
Edited by Brian Drysdale, 05 December 2010 - 05:17 AM.
#3 Edgar Dubrovskiy
Edgar Dubrovskiy
  • 348 posts
Posted 05 December 2010 - 06:37 AM
Here are some varieties: http://www.google.co...ved=0CCwQrQQwAA
#4 Raj Kumar Macwan
Raj Kumar Macwan
  • 6 posts
  • NYC
Posted 25 December 2010 - 07:16 PM
I have never used a viewfinder but use the good old style of two thumbs touch making 35mm frame to look at he camera positions/angles.
Is this tool worth the investment ? I pretty much on shot films mode and in HD format which is easier to move around if needed accurate frame/angle positions.
