Converting 30p to 25p
#1 Chris Alex
Chris Alex
  • 36 posts
  • Greece
Posted 06 December 2010 - 01:38 PM
I shot a music video with Canon 5D mk2 and the footage was 30p. I converted it to Apple ProRes HQ to edit it and kept the same frame rate. So I edited it at 30 frames. It didnt occur to me that Id have to print it on tape at 25fps (PAL standard) so It can air at that rate.
Now Im wondering if I should finish my video and export it and THEN convert it to 25p OR stop where I am, and convert all my footage to 25p and edit on top of a 25p export of what I already have.
Ive converted a mixdown with MPEG streamclip from 30p to 25p and with frame blending the cuts look like a 1 frame dissolve. Without frame blending the motion looks a bit choppy.
Ive converted footage from 30p to 25p and in the motion I can see the frames blending.
On the other hand I will upload the video on YouTube. Isnt it better if I keep it 30p for YouTube?
Any advise would be useful since Ive stopped editing till I resolve this matter.
Thanks!
#2 John Sprung
John Sprung
  • 4635 posts
Posted 06 December 2010 - 02:18 PM
Since you're in 30p, finish in 30p. Then find a facility that has the Arri "Relativity" system available. Have them convert to 25 for you. It's the only conversion method that looks at all good.
#3 Chris King
Chris King
  • 7 posts
Posted 21 April 2014 - 09:02 PM
I think Brorsoft Video Converter can help you to convert you Canon MOV from 30p to 25p. Just set the right frame rate before start conversion.
#4 Freya Black
Freya Black
  • 4164 posts
Posted 24 April 2014 - 06:22 AM
Thanks!
30p can be a problem!
The easiest thing might be to slow your footage down to 25p and timestretch the soundtrack! :(
You could also slow your footage down to 25p and completely recut it. That's not going to work to well if the video has any lipsync tho.
You could attempt to convert the raw footage to 25p in MPEG Streamclip and then re-edit it at 25p which might solve any issues with cuts if the cuts don't occur on a frame blend.
You could maybe combine the last two of these strategies for different parts of the footage.
Best thing to do if you were to do it all over would have been to shoot at 24p or 25p.
You tube is fairly framerate agnostic. In fact at 24 or 25p there is less data it has to stream to people as there are less frames! Less data means it will probably actually stream better!
If you were just making the video only for youtube then 30p would be fine but clearly that isn't the case.
Freya
Edited by Freya Black, 24 April 2014 - 06:25 AM.
#5 Freya Black
Freya Black
  • 4164 posts
Posted 24 April 2014 - 08:26 AM
Here is a really great video from Eugenia Loli where she shows the 3 different options:
Freya
