Letus Ultimate, P+S Technik Pro35 compareson
#1 Mostafa Al Taher
Mostafa Al Taher
  • 5 posts
  • Cairo, Egypt
Posted 30 December 2010 - 10:28 AM
hi.
I was searching for a high quality 35mm adapter to use it with a sony F900R HD cam, and I saw a lot of footage of tests online and I liked the results of Letus Ultimate. comparing it to Pro35 - as a cost wise - it's very cheaper, but I didn't do any eye tests on letus cause we don't have it in Egypt.
after this I was doing some comparisons on pCam and I found these results :
50mm lens on Pro35 gives (75mm Vertical Match, 81.8mm Horizontal Match) on letus
a 135mm lens from a 5 feet distance on Pro35 gives this view :
a 135mm lens from a 5 feet distance on Letus gives this view :
so my question is, if any body made a test on these adapters, is these results are true cause every company says that the adapter gives the same perspective and DoF of the 35mm Cameras.
Thnx alot
#2 Mostafa Al Taher
Mostafa Al Taher
  • 5 posts
  • Cairo, Egypt
Posted 30 December 2010 - 02:39 PM
hi again.
I have a little correction, the two previews is inverted. the first one is for the Letus adapter and the next one is for the Pro35.
sorry for this mistake
and thnx again
