Speed ramp in camera, or in post?
#1 Karel Bata
Karel Bata
  • 487 posts
  • London - a rather posh bit
Posted 06 January 2011 - 07:10 PM
Call me old skool, but I always thought it looked better done in camera, however today I talked to a very experienced cameraman who said he couldn't see the difference. You'll understand if I won't say who it was.
Thoughts?
#2 John Sprung
John Sprung
  • 4635 posts
Posted 06 January 2011 - 08:59 PM
It's better to do it in camera. Arri's Relativity might be the best way to do it in post, but it's expensive. If you want to do it in post, shoot the highest frame rate and largest shutter angle you can afford.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 07 January 2011 - 11:15 AM
It can be very difficult to get the timing just right in camera. And some cameras cannot shift speed as quickly as you might like or on a linear or non linear accelleration/decelleration curve as you might wish. That's why post control is so nice.
#4 Phil Rhodes
  • 12167 posts
Posted 07 January 2011 - 11:30 AM
Having done quite a lot of this sort of thing with Twixtor I can only agree with Mr Gross. Given the motion of an actor, there is somehow a very tightly defined moment at which speed should change, and a characteristic with which it should change, in order to look somehow nice. I am surprised that anyone ever got this exactly right in camera, especially on film.
I wonder how the desktop software plugins compare to Relativity.
In either case my default assumption would be to shoot it all at the highest frame rate you can feasibly achieve, and do the ramp in software. Definitely shoot tests, as the software can be picky about what works and what doesn't, especially if you can't shoot at a frame rate as slow as your slowest intended output speed - which is unfortunately common.
PS - Kaboom -
#5 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 07 January 2011 - 11:34 AM
BTW, with the advent of digital high speed cameras like the Phantom HD Gold, I don't say to shoot at the top frame rate of the expected finished shot. Instead I suggest shooting at twice that speed. This allows more options in the speed at which the ramping will occur without having to generate too many interpolated frames.
