Sound on cinevator
#1 Roman Dymny
Roman Dymny
  • 2 posts
  • Sound Department
  • Paris, France
Posted 07 January 2011 - 12:41 PM
Hello Everyone
I'm a sound re-recording mixer. I have to mix a movie that will be transferred to film with cinevator, with direct positive print. But I'm wondering if the optical transfert of sound will be the same as usual. Has anybody any experience of sound optical transfert with Cinevator? Are thoses transfert the same than traditionnal ones?
Roman Dymny
#2 Brian Drysdale
  • 5197 posts
Posted 07 January 2011 - 12:58 PM
From what I recall you don't need a sound neg, but I'd assume you need same mix and Dolby that you'd use for any other print. I'd check with whoever is doing the transfer what they require, for example they may be able to do the Dolby.
#3 Freya Black
Freya Black
  • 4164 posts
Posted 07 January 2011 - 02:52 PM
Preety sure thats right, the soundtrack is printed at the same time as the picture, straight to print, and can be analogue or dolby digital. You prepare the soundtracks in the same way but you just avoid the need for a sound neg.
Worth checking with the cinevator operators you are using tho.
love
Freya
#4 Roman Dymny
Roman Dymny
  • 2 posts
  • Sound Department
  • Paris, France
Posted 19 January 2011 - 01:22 PM
Thanks for your answers.
I think also it is logical that there is no "special" mix for cinevator, because the print is supposed to be the same than one made with traditionnal film transfert... but some cinevator operator wanted me to make a special mix... with severe limitation of the analog mix!! (not good for sound!)
#5 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 20 January 2011 - 09:51 AM
Optical tracks on 16mm aren't exactly high fidelity in general I believe.
#6 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 20 January 2011 - 12:45 PM
I read that some 16mm film-makers have experimented with recording a DTS time code sync track in place of the analog optical sound track. On paper, it should work. In practice? Who knows.
DTS System
#7 Brian Drysdale
  • 5197 posts
Posted 20 January 2011 - 06:49 PM
Cinevators transfer to 35mm.
