CA-1 to PL adapter?
#1 Robert Szanto
Robert Szanto
  • 13 posts
  • New York City
Posted 11 January 2011 - 01:10 PM
Has anyone had any experiences with the CA-1 to PL mount adapters that are floating around ebay? I've heard from other places that an adapter like this wouldn't allow for infinity focusing. Any other ways of getting a CA-1 lens on a PL mount camera?
#2 Jean-Louis Seguin
Jean-Louis Seguin
  • 750 posts
  • Montreal, Canada
Posted 11 January 2011 - 01:36 PM
Quite right. The inexpensive adapters sold by an eBayer in The Netherlands do not allow infinity focus.
It may be possible to have a custom PL-mount made for your lens but again it will depend whether the physical dimensions of lens will allow such a modification.
Cheers,
Jean-Louis
#3 John Sprung
John Sprung
  • 4635 posts
Posted 11 January 2011 - 02:15 PM
To say for sure, we'd have to know the flange-focal distance for the CA-1. I tried Google and Wikipedia, and came up empty.
CA-1 was never a good lens mount, it was tempermental and loose. So, if you have any CA-1 lenses, you have to decide whether to get them re-mounted, or preserve them as antiques.
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 11 January 2011 - 02:53 PM
We can supply a proper adapter from CA-1 to PL.
The CA-1 was pretty close to the ARRI standard, so making a proper adpapter to PL is not impossible, you just have to know what you're doing.
Feel free to contact me offlist.
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 11 January 2011 - 04:40 PM
The CA-1 flange-focal distance is 48mm. Don't recall the mount diameter, but it is wider than the Arri std. & bay.
The PL and other Arri flane-focal distance is 52mm.
#6 Dima Turaev
Dima Turaev
  • 13 posts
  • Russia
Posted 03 March 2011 - 08:38 AM
Hi! And what is the СA-1, put photos. And in Russia in general can be any lenses in the PL mount to change, if interested write to the PM.
#7 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 03 March 2011 - 06:37 PM
The PM? Do you mean Vladimir Putin?
#8 Ian Cooper
Ian Cooper
  • 469 posts
  • England
Posted 04 March 2011 - 05:30 AM
PL Mount is 54mm diameter with a FFD of 52mm
CA-1 Mount is 46mm diameter with a FFD of 48mm.
As already stated, an adapter to fit a PL mount lens on a CA-1 mount camera is not feasible - the lens is already too large to fit in the camera before you've put it in an adapter.
An adapter to fit a CA-1 mount lens on a PL mount camera might be feasible depending on the lens in quesion. The smaller diameter of the lens means there would be a 4mm wall thickness on the adapter, this just leaves the different FFD. To work perfectly the CA-1 lens seating surface needs to be recessed 4mm behind the PL mount seating surface ie. back inside the camera.
In most real world situations I suspect there won't be enough room to actually accomodate the back end of the CA-1 lens body within the available space. However, if you had a small enough diameter lens then it might be possible to get a custom adapter made. Really the lens body would need to be no larger than the CA-1 mount itself. Some of the bolex c-mount lenses seem fairly small diameter, so perhaps if you'd come across one of those which had been modified to CA-1 mount you might be able to get away with it, but I guess the chances of all that are pretty slim! :lol:
#9 Dima Turaev
Dima Turaev
  • 13 posts
  • Russia
Posted 20 March 2011 - 02:16 PM
personal mail
