Sound proofing
#1 Justin Ciminero
Justin Ciminero
  • 5 posts
  • Gender:Male
  • Occupation:Other
Posted 03 February 2011 - 06:56 PM
I'm looking to sound proof my noisy bolex camera for sync recording. Does anyone know a flexible material I can tailor & wrap around the camera; reducing the noise to almost 0db? Keep in mind this camera is so loud, a shotgun mic can pick it up 20ft away facing the other direction.
#2 Brian Drysdale
  • 3252 posts
  • Occupation:Cinematographer / DP
Posted 04 February 2011 - 08:18 AM
You won't get it to Odb, even the best silent motion picture cameras only manage 19 dbA.
There are so many ways sound can leak, that I don't think there are any flexible materials that will do more than reduce the sound level. I built a blimp for a Bolex and it was still louder than any 1960s camera silent 16mm camera - it was at best mid thirties dbA (it was never tested).
#3 Justin Ciminero
Justin Ciminero
  • 5 posts
  • Gender:Male
  • Occupation:Other
Posted 04 February 2011 - 01:42 PM
...I built a blimp for a Bolex...
Do you have a picture of the blimp you built?
#4 john spader
john spader
  • 12 posts
  • Occupation:Producer
Posted 13 February 2011 - 03:08 PM
If you call Guy in Nevada, he might have one of the original jackets that goes around your bolex.
He's french, and knows about everything when it comes to film cameras.
Guy Bodart
CAMERASPRO
http://www.cameraspro.com
#5 Bruce Taylor
Bruce Taylor
  • 481 posts
  • Gender:Male
  • Occupation:Other
Posted 14 February 2011 - 02:38 PM
Yea, the Bolex (except for the Bolex Pro, which really wasn't a Bolex) is LOUD. I have never heard of anyone building a truly effective blimp, it would just about always be cheaper and better to shoot with a camera designed to be silent.
"flexible material I can tailor & wrap around the camera; reducing the noise to almost 0db?"
That would be a "barney." And they will not silence an MOS camera like a Bolex. Custom Upholstery Products makes barneys for all sorts of film cameras. He has a secret blend of materials (including lead foil I believe) he uses to deaden sound. It will help but not eliminate noise. He made one for my Kinor 35H, a "silent" camera at about 32db, but too noisy in small reflective rooms. CUP's barney brings the noise level down to acceptable in these cases.
In general I think you'd be better off with an Arriflex 16BL, an Eclair ACL or NPR or a Cinema Products CP16R. They are all quite cheap these days.
#6 Brian Drysdale
  • 3252 posts
Posted 28 February 2011 - 02:47 AM
Sorry, it was years ago, but it did look like something from the 1930s or 40s and was made from chipboard. There was a base and back piece, while the main cover slide forward. The camera was mounted on a metal plate that was mounted on rubber mounts - I seem to recall these being car exhaust suspension mounts. The clear glass was in the front of the main cover and there was a metal sunshade fitted to the front.
It was a pain to use and in the end most of the film was shot with an Arri 16BL and that was a breeze by comparison.
#7 Tony Koretz
Tony Koretz
  • 15 posts
  • Gender:Male
  • Occupation:Sound Dept.
Posted 04 December 2011 - 11:07 PM
You need one of those "Cones of Silence" they used on Get Smart, and lock the camera man under it!
