Using out of date KODAK VISION2 500T Expression 7229 16mm film
#1 Mohammed Tahir
Mohammed Tahir
  • 24 posts
  • UK
Posted 06 February 2011 - 12:57 PM
Is it worth trying KODAK VISION2 500T Expression 7229 that expired in 2006? Should it be clip tested? What rating would you use if you were to shoot with it?
Mohammed
#2 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 06 February 2011 - 07:20 PM
Is it usable, Quite likely,depending on how it has been stored.
Should it be clip tested - Would be a good idea.
Reduced rating, possibly, Amount would have to be worked out by tests.
#3 Adrian Sierkowski
  • 7374 posts
Posted 06 February 2011 - 07:54 PM
Clip test it first, and then go from there. I've used very old stocks before (I'm talking 800T and 320T visions) which was labeled by the lab "Do not shoot," and the results were what I expected. Foggy, grainy, interesting, and needing to be over-exposed at least 1 stop, generally 1.5 stops. It worked for what we were doing, which wasn't looking for "normal" images.
#4 K Borowski
K Borowski
  • 3905 posts
Posted 06 February 2011 - 08:54 PM
Adrian's advice is pretty much what I would say about overrating.
I'm curious, though. Kodak MP stock doesn't "expire." How do you know it "expired" in 2006? There is a level of base fog in a clip test that indicates a stock is too old. It varies from stock to stock or manufacturer.
So I'd appreciate your clarifying for us the method used to determine a stock had expired in '06. Did it fail a base fog test then?
#5 Mohammed Tahir
Mohammed Tahir
  • 24 posts
  • UK
Posted 06 February 2011 - 09:23 PM
Thanks everyone for the info. I believe the film has been refrigerated all it's life (from what I'm told). I don't have the film - it's something someone is selling and I was thinking of giving it a try. I sent the batch code to Kodak and they said it expired in 2006 - I'm not sure what that means now you've raised it.:rolleyes:
#6 Marcus Allemann
Marcus Allemann
  • 26 posts
  • 2nd Assistant Camera
  • Berlin
Posted 21 February 2011 - 08:00 AM
i just sat in on a telecine session this morning where we used that exact stock with short ends refrigerated from 4-5 years ago with some 200T as well.
was curious to see how differently they behaved but was pleasantly surprised to see the difference to me was barely noticeable, but then again, I don not posses the trained eye of a professional (although I am trying!).
I'm now curious to see the effects of old UN-refrigerated stock.
#7 K Borowski
K Borowski
  • 3905 posts
Posted 22 February 2011 - 12:09 AM
One thing I'd like to add, not sure why I didn't mention earlier: '29 is THE grainiest stock Kodak makes, maybe the grainiest current color neg. stock out there made for ECN-2.
So figure it will probably be as grainy probably as bad as 800T '89 was, even with an underrate. Let us know how the test goes. . .
