E-6 Alternative Bleach?
#1 Yuri Smishkewych
Yuri Smishkewych
  • New York Metro Area
Posted 10 March 2011 - 11:13 AM
Hello everyone! this is my first post on cinematography.com. I'm a DP that works multi-format but lately I've been shooting more film then digital. We are considering using an alternative copper chloride bleach process on Ektachrome- has anyone ever tried this? I know there were some still photographers using this in the early seventies-i haven't found much other than that and a few 135/c-41 stills on the net.
thanks,
-yuri
#2 Friedemann Wachsmuth
  • 122 posts
  • Hamburg, Germany
Posted 13 March 2011 - 08:01 PM
That sounds interesting. May I ask why you want to alter the bleach? What do you hope to achieve?
I absolutely have worked with other bleaches, but that alone did not change results too much. I might help better once I know what you are trying to get.
#3 Yuri Smishkewych
Yuri Smishkewych
Posted 14 March 2011 - 12:08 PM
hello from ny, thank you for your quick reply. we are trying to emulate the look of early-20th century Photochrom Liths for a title sequence that won't require too much work in post. I was suggested by a (still) photographer that in their experience (especially when in weak cu chloride solutions) he got something that was quite similar to the samples I showed him. The effect was somewhat similar to the look we're shooting for. I'm beginning to suspect it may just be a bypass-effect due to the weak solution nothing more, Does this sound right? Or does a cu bleach have a specific color shift?
-thanks
yuri
#4 Yuri Smishkewych
Yuri Smishkewych
Posted 21 March 2011 - 09:01 AM
correction....incorrectly i thought that my photographer friend was doing E6. turns out he was xprocessing ekatachrome in c-41 chemistry as a negative then printing it to get the "Photochrom Look" in combination w/ a short cu bleach.
Has anyone ever experimented/used this process? Any advice/help is greatly appreciated!
-thanks,
yuri
here's my first attempt for that look on 135/C-41 not the best pic or scan but its kinda what e're going for:
